Question about Bosch Axxis WTA 3510 Electric Dryer
Access to Light Bulb
Bulb needs changing...
Interrior access looks somewhat straightforward, but thought I'd ask the question.
Especially since it's a moisture sealed area -- and were talking about an electric light bulb.
Tips / Warnings appreciated.
  • christian_fl Apr 20, 2008
    I have a Bosch WTL 5400 with the same problem, burned out light bulb. Suggestions to replacement and cautions appreciated.
    Novelist:
  • 130 Answers
You have to pull the facia above the door to access the lamp. Between the frame and cabinet on the sides insert a putty knife an pry out, the open the door, insert the putty knife under the panel and pry out. Now remove the torx 20 screw to remove the cover to access the 230volt lamp. You will need to order it from Bosch.
Posted on Apr 26, 2008
How do I change the time back one hour
You don't say anything about the watch you're trying to adjust, and that makes answering the question impossible. An analogy - 'How do I change a light bulb?' would require a lot of extra information to answer although it seems a straightforward question. Screw or bayonet fitting (both available in a range of sizes), voltage, wattage, lumens, colour temperature, incandescent/halogen/LED, physical size of bulb, knowledge of electrical safety, access to the bulb fittings etc. etc. etc.
Nov 09, 2017 | The Watches
Acura rdx 13 bulb
Open the hood and look behind the headlight housing. Turn a 1/4 turn counter-clockwise and the bulb housing should come out. Remember not to touch the bulb with your fingers.
Update: Oh ok you know that you say? Then why ask? I thought I'd help. You're welcome. Put a little effort out and Google your answer then. See you next Tuesday!
Feb 03, 2017 | Acura RDX Cars & Trucks
How do i replace head light bulb to my honda pilot 2003
If you can reach it from behind you simply turn it and pull it out. Snap out the dead bulb and replace. If you can not physically get behind the lens then you need to remove the lens to gain access to your bulb. That is easy to do. There should be two or three bolts/screws holding the assembly in. Remove them and the lens will pull out. After pulling it out you can access your bulbs. Do no touch the surface of the new bulb on install. Your finger oils will shorten the life of the lamp
Oct 10, 2014 | 2003 Honda Pilot
How do i access rear light
On my 2007 TDM 900 the rear light bulb is accessed by removing the seat and reaching into rear "cowl". The light bulb holder twists and then pulls out. It's quite a small space, especially if you have big hands ;-)
May 28, 2013 | 2002 Yamaha TDM 900
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
How do you access the outside tail light to change the bulb on a 2008 Hyundai Sante Fe?
You can access the bulb by going to the rear of the car and removing the internal side panels at the opposite side of each tail light. You should see the covering and the socket for the light which you need to remove to gain access to the bulb.
Apr 04, 2011 | Hyundai Santa Fe Cars & Trucks
I just purchased a 2004 forestor and realized that the rear turn signal needs a new bulb. what are the basic steps to complete this task
There should be an access panel from the trunk-area. Find the burn out bulb, untwist it, and insert new bulb. It's a very straightforward process.
Feb 26, 2011 | Subaru Forester Cars & Trucks
Replacing brake light on a subaru outback limited wagon 2000
How To Install Replace Change Taillight and Bulb 2000-04 Subaru Outback
Apr 07, 2010 | 2000 Subaru Outback
Light has stopped working in microwave
Do you have an owners manual, if not go to the manufacturers website and download one, or call and get one, it should have instructions on changing the bulb, I have changed bulbs in a variety of microwave type ovens, and not one was the same access, some you have to remove the side control panel face, others a top plastic case part, too many to list, you need to find out the manufacturer's directions and or study the unit, with enough looking you will find an access point, generally this is somewhat complex, a few screws minimum, next is to be careful in the disassembling of a microwave, if you are not sure where or what you are taking off, you can take off, parts that allow the microwave to leak, or become dangerous to be around, find the specific instructions, it will make life much easier for you.
Will
Nov 30, 2008 | Belling Microwave Ovens
Mirror indicator
under the mirror there should be a 1 1/2 slot door under mirror that looks like a flat lid this will be flush with mirror moulding where it looks like a quarter can turn it
this is the light access panel the detachment screw is threw this panel to take off mirror then you can access the bulb
May 21, 2008 | 2004 Volkswagen Golf
Bosch Axxis WTA 3510 Electric Dryer Logo
227 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
