Question about Phase Linear UDV9010 Car DVD Player
Amp how do i connect my amplifier remote wire to my phase linear dvd player
    President:
  • 624 Answers
It should have a blue wire from the harness on the back of the player for turning on the amp, it may also be labeled "antenna" or "power antenna" or "P con". That is the one to run to the remote turn on of the amp.
Posted on Jul 01, 2008
I need the color coded wiring diagram for a linear UVD9010
Red wire= 12V switched
Yellow= 12V constant (memory)
Black=ground
Blue=Amp remote wire
Pink=emergency brake safety
Speaker wires are paired by color with black stripe being negative
Jan 12, 2012 | Phase Linear UDV9010 Car DVD Player
Phase linear model UPA424 wire diagram
YOU WILL NEED A SOLID WIRE FROM UR DECK TO UR AMP 4 A REMOTE WIRE AND A GOOD SET OF RCA JACKS
Jan 31, 2010 | Phase Linear UPA424CS Car Audio Amplifier
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
My phase linear uv7ts wont come on at all
check your ground connection and all wires for loose connections.
match wires according to color.
Jan 28, 2009 | Phase Linear UDV9010 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Phase Linear UDV9010 Car DVD Player Logo
112 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
