Question about Toshiba e-Studio162D Copier
SYSTEM ERROR H4-00
IT SAYS SEE USER GUIDE SYSTEM ERROR- NOT IN USER GUIDE- MACHINE WILL NOT EVEN TURN ON
    President:
  • 2,072 Answers
Give this a try, Normally this helps.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Mar 10, 2008
  • Rick Kasper Mar 11, 2008
    I see you listed this as helpful. If the procedure did not clear the code. You will most likely have to replace the fuser to resolve the H4 condition.
Can you please help me find the auto button on toshiba e162d copy.
Posted on Jul 09, 2008
Sharp AR-m150 refuse to copy, print and scan asking for user guide system error (H4-00)
error is sometimes a way for the machine to go into safe-mode when there is power fluctuations , or a problem with the machines thermistor or thermostat
Aug 04, 2013 | Sharp AR-M160 Black and White Copier
I have a FO-2080 fax machine and it is displaying a message system error (E1-00) and will not work at all.
Page 69 on operation manual suite Source: http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/fax_man_FO2080_suite.pdf
Error indicator is lit or blinking.
SYSTEM ERROR [XX - XX] REFER TO USER GUIDE
When [L1-00] appears, the scan head locking switch is locked. Turn off the power, release the scan head locking switch, and turn the power back on page 13 on the manual
The machine will not function. Turn the power switch off, wait about 10 seconds, and then turn on the switch again. If this does not clear the error, remove the power cord from the outlet, and contact your SHARP service center.
Mar 08, 2011 | Computers & Internet
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
"Unable to Print" error message
you need to check that no paper is jammed in the gears - even tiny little scraps can cause the machine to throw up an error message.
Mar 31, 2010 | Brother IntelliFAX 1840C Plain Paper...
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Error Message: Unable to Clean
Machine error 46 ("Unable to Clean") indicates the wasteink "sponge" as full, which disables the machine's ability to clean. To fix this, you could get the needed part from a Brother parts dealer and enter the servicemode to reset the counters. However, the more reasonable thing to do would be to just change to another machine. You could also have the machine sent to service, but that most likely would not be worth the trouble. The error is pretty common on old Brother inkjets, so it'll come back eventually even if you replace the part. Newer machines should not have this problem.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Kenwood BM200 : error message EL
From the owners english manual:
"E-L or E-S appears in display and machine cannot be turned on: Bread maker is malfunctioning. See “Service and Customer care” section."
Technical: Firstly check that the thermistor securing nut is not loose, and, if there is no evidence of thermal compound, then apply a little to the back of the component. Most times this cures the problem. If the appliance is still intermittent, it will be necessary to replace the thermistor assembly.
May 13, 2009 | Kitchen Appliances - Others
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Toshiba e-Studio162D Copier Logo
183 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
