Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Posted on Mar 22, 2010
SOURCE:
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My Magnavox MWR20V6 DVD VCR Combo shuts down, after 5-10 seconds, following start-up (on/standby button). I saw "E1(rear)," on the TV screen, just before it shut down the last time. I suspect...
Before anything, I would attempt to see what the E1 code signifies. But usually when those things just shut themselves down it is because of a serious problem in the power supply. I think it is time to go shopping.
Sep 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Sep 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR runs 10-15 sec. shuts off.
most vcr decks are clones of other decks .find out what deck is fitted in that model ...might find that a easier way to trace a service manual. check R.S components parts ..i'm sure they have a section on vcr decks and a large parts and service sections with pictures to help you identify your deck. ps if you have never done this sort of thing before i would think hard on whats involved it can be very time consuming and awkward to do....deck timing can be a real pain to get right. i would start with the easy things to change first like the pinch roller.anyway hope this helps a bit ..farr64
Apr 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR problems
My solution was to call my warranty company. I'm sending it in and getting my money back. They said it would cost more to fix it than I paid for it.
Nov 10, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6
The unit has to be turned off for the timer to activate. Let me know if it works.
Jul 23, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can't play any VCR tapes or DVD's in my Magnavox. Shows E1
It may be a timer setting after a power problem. On page 90 of the manual there are setups for the timers My VCR won't do things without the time set either. The manual may be downloaded here.
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Basically get into the setups and set the time and hit enter. I hope this works.
Sep 12, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
291 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
