National TV Model No. TC-2185TR
I could not found video channel on this tv and unable to play any movie through DVD. Pls tell me abt its video setting
MikeNJ1964
  • 398 Answers
SOURCE: Lost Remote Control
Do a google search for "emerson remotes" (in quotes) and take your pick. I have ordered them by model number from Fox International at 800-321-6993.
Posted on Jul 09, 2007
  • 749 Answers
SOURCE: Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Posted on Oct 30, 2008
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
CRTN
  • 716 Answers
SOURCE: How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Posted on Jan 05, 2009
SOURCE: how to access the video input channel for my Konka tv?
press menu twice and once + or - volume. and tv will enter in video imput mode.
Posted on Apr 08, 2009
I have a Hikona combined 14" tv and dvd player,
Try going into your settings in the tv and try changing were the signal comes from and manually 're time sometimes works in pore signal areas and moving the aerial may help
Nov 28, 2017 | Televison & Video
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
DVD is playing but you don't see it on the tv . Do I have to put TV on a certain channel while playing DVD?
pls check dvd AV cabel .
if ok
then
playing dvd first and see dvd back side pin .
VIDEO OUT
after see on your dvd remot cantrol and check interface key if yes then use key to set display on screen S-VIDEO and see the picture is normal .
if not then.....
pls see the dvd back side
GY /BU /RV three pin
pls video out pin is plugge out and concting with step by step in all three pin
if sum picture on screen pls. canect and hold .
after that use dvd remot cantrol and selact SETUP key to on and see and open video interface menu pls set video system is select S_video.
after that reconact video pin is VIDEO_OUT and see picture is normal .
Oct 08, 2009 | Panasonic DMR-E75V DVD Player/VCR
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Mar 04, 2008 | Konka K1938U 19" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
