No internet access
I just had pixius internet installed with a linksys wrt54g router. I can't get on the internet on my pc.I can with my laptop.
  • 655 Answers
Do you have wireless network installed on your new pc.
Actually to connect a wireless router you must have a wireless device installed on your new pc.
After installing the device and driver you found an icon for the device.
And will show you the list of wireless network avail to your pc.
Then select your network and click on connect, if your network is security enabled then it will ask for passward enter password and your pc will be connected to your router.
If you have done the above and still you are not able to connect network then click on wireless connection icon of your PC, navigate Status click on it.
Then Wireless Network Connection Status window will be appeared. Click on Properties button, then Wireless Network Connection Properties window will be appear.
Go to TCP/IP settings and make a valid setting for your PC.
After that you can get connection and may share the internet connected on another PC of your network.
Thanks
Iqbal
Posted on Mar 10, 2008
  • 101 Answers
Disable the other adapters and try agan...
then use use the set up Home or small office networking wizard in the left to complete it
hope it worked !
My niece gave me a Linksys WRT54G wireless broadband router. But she couldn't find the installer. How do I install it to my computer?
1)Connect lan cable on any of the port in router and connect your pc? And check whether your pc is getting automatic ip and check what is the gateway defined there??And just put that ip(if default it will be 192.168.1.1) in your internet explorer and access your router.
2) If even connecting your pc its not getting any ip then reset you wireless router and login using internet explore 192.168.1.1 ip?
Sep 22, 2010 | Linksys Wireless-G WRT54G Router
I shut down my laptop and when restarted it the next morning the linksys wireless G software was uninstalled? laptop can not access the wireless router.
You can access the router by opening up your internet browser and typing in 192.168.1.1. This is the default address for your linksys router.
Good Luck,
NOLA Tech
Jan 28, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Can not connect to internet wireless Installed Linksys but did not work. tried to install again, ask for default info. dont know how to reset router to default settings.
Default settings for the WRT54G can be performed by pressing the
reset button for at least 10 seconds and then release it.
The router can be accessed by opening internet explorer:
type in adres http://192.168.1.1 and enter.
The login for the router default settings is:
user: [leave blank]
password: admin
There are about 10 versions for this type router on the Linksys
support site, "Get Downloads" like manual and firmware :
http://www.linksysbycisco.com/UK/en/support/WRT54G
Note: from the support page select your version first
Sep 07, 2009 | Linksys Wireless-G WRT54G Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Router with ethernet connection & wireless. Has been working perfectly for ages with a wireless laptop & Samsung i600 phone. whether coincidence or not a few days ago I logged someone else's...
looks like the new laptop has been assigned the same ip address as your old latop so it wont allow u access...renew the ip address, assign ur old lap top a new one or just reboot the router so it will issue u with a new ip address.
Feb 15, 2008 | Linksys Wireless-G WRT54G Router
No internet connection
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
124 people viewed this question
Alun Cox
David Payne
David Payne
