Question about Dell 1600n All-In-One Laser Printer
Over heat messege
Hi goodmorning how do i locate my dell 1600 printer fuse
  • Anonymous Mar 25, 2008
    open heat error
  • Cietra Mar 27, 2008
    I started to print a document, but the printer started beeping. So, I took a look and there was a message that said "Over Heat". There was a burning smell, so I turned off the printer. I waited a few minutes and turned it back on. Now, it goes back from "Open Heat Error" to "PC Print Pending". How do I fix this?
There are apparently two causes of fusers going bad in these printers.
First - Old age. The fuser is old and it dies. In that case, a new fuser will fix the problem.
Second - The fuser lamp control circuitry is bad. This can cause the fuser lamp to stay on all the time - which it ISN'T supposed to do. This in turn causes an overheat condition which will burn out the fuser and cause a burning smell.
If the second condition above is occuring, it will simply destroy a new fuser if one is installed without correcting the regulation problem. I have read that the controller board is serviceable separately.
Posted on May 11, 2008
    Scholar:
  • 105 Answers
Chances are that you are looking for your printer FUSER, not a fuse. The fuser is the rolling element that bonds (via heat) the plastic charged toner particles to your paper. It is located in the rear of the printer. Unplug, remove four screws that secure the back of the printer. Once removed, you will see a circuit board and the fuser. The fuser has two sets of wires (one on each side) that should be unplugged with your hands. Remove the four screws that keep the fuser module in place and replace that module (call Dell parts for replacement).
Posted on Mar 27, 2008
Roadstar has no power when key is turned on
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 yamaha 1600 roadstar main fuse location Google Search XV1600 Yamaha Road Star Where are my fuses
Yamaha XV16AL Service Manual
OEM parts for Yamaha
Yamaha Road Star XV16ARC Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 17, 2012 | 2001 Yamaha XV 1600 Wild Star
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
I have a xerox machine for ricoh mp 1600 le. now i have a error of 542. so please tel me what is the problem of xerox machin?
SC542 code on Ricoh's means that the fuser unit is not heating up properly. The fusing unit is the part that "fuses" or fixes the toner onto the paper and is located right where the paper exits your machine. Most of the time the SC542 code means that the thermister(s) in the fusing unit have failed. The thermister measures the temperature in the fusing unit. When these go bad the machine can not "see" the unit heating up so it throws the code. The thermisters will need to be replaced and the code cleared out from the machines memory by gong into the service mode. I would recommend calling your local service provider to effect repairs.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Office Equipment & Supplies
Cleaning mirrors on HP Laser 1600
The printer does not have mirrors if your talking about the lasers they are situated behind each of the toners through a long gap hope this helps.
Nov 28, 2009 | HP LaserJet 1600 Printer
Dell MFP 1600n Power Supply Failure - need part identification
I found a replacement board on the internet for $89.00, then realized you could replace the entire unit for about $200. So I threw it away.
Oct 01, 2009 | Dell 1600n All-In-One Laser Printer
Color ink cartridge does not click in properly when installing new cartridge..gives error messege that cartridge is missing...when in fact it is there...will only print in black ink when I ignor error...
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Sep 01, 2009 | Dell 948 All-In-One InkJet Printer
I am not being able to use the DELL MFP 1600 Laser
Replace pick up rollers. very easy and very cheap.
Jul 15, 2009 | Dell 1700 Laser Printer
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Dell 1600n All-In-One Laser Printer Logo
461 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
