Question about RCA Scenium HD65W20 65" Rear Projection Television
Double image. T.V. has double inmage. replaced small chip board No. 251174 Double image is gone but tv will no longer autoconverge. Image seems too large for the screen and or sensors to converge properly. Also after about 30 minutes of the tv being on it will start acting like someone has a remote in their hand and acts wildly switching between inputs until finally completely locking up on the antenna input. Functions of remote will no longer work. even buttons on tv itself are froze up. can only turn off tv by pulling power.
    Genius:
  • 1,030 Answers
You have hd65w20 selenium? this is a dt307 rca chasis. Why did you replace 257154 which is called delection sip. this has little with convergence... was convergence the orginal complant?
Posted on Apr 04, 2008
  • 61 Answers
First when replacing the small sig. board a full convergence must be done,the other trouble is most likely the front panel buttons,this is a repair a service center must do,sorry best i can do from here
Posted on Apr 01, 2008
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
My hitachi 60"ultravision tv has a double image at the top in blue and yellow. the magic focus has no impact. any ideas?
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
Feb 16, 2015 | Hitachi 60SDX88B 60" Rear Projection...
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
TV image is one greenish color image hardly visible.
two big chips on one seprate pc board
sk_ _ _ _ _ _ ? get the number google it
cost about 10.00- 20.00 etch order them
go to raido shack get solder soldering iron
40watts and solder braid (whicket)
remove the solder pull the chips ,one
small screw holds them to the heat sink
replace with ordered parts set up
covergance Done. you just saved 300.00
Jun 30, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
RCA Scenium HD65W20 65" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
