Question about Refrigerators
20 Year old sub zero. The refrigerator side is freezing the food, the dial is set at 6. I tried to lower it to 5 but the fan in the Freezer turns off.
  • 259 Answers
Most refrigerator-freezers have a control that adjusts the operation of the cooling system of the freezer only. In such appliances, any control for the refrigerator is simply a mechanical system of opening or closing vents between the refrigerator and freezer to let in more or less cold air.
Remove the temperature control dial or housing. Pull the dial straight away from the wall. Remove the temperature control. If there is a housing, it either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. The control will be connected by two wires. Label the wire placement on the control before disconnecting the wires. The wires are connected to the switch with slip on connectors. Firmly pull the connector (do not pull on the wire) off of the control's terminal. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the control for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. Turn the control to warmest setting or off. The multitester should display a reading of infinity. If the control does not have an off position, the reading should be near the infinity end of the scale. Now change the control to the coldest setting and retest. The display should read zero ohms. If the control does not pass both of these tests, the switch should be replaced
Here is a link to more information and pictures on refrigerator repair:
http://www.acmehowto.com/howto/appliance/refrigerator/check/tempcontrol.php
Posted on Mar 10, 2008
    Master:
  • 351 Answers
Dear SJANDJUNEL,
Contact to Authorised SUB ZERO service centre ,which is near to your permises. it seems your dailer is faulty and you have to replace this faulty Dailer.
Cheerup and Be Happy always
  • Refrigerators Master
  • 13,433 Answers
I supose the fridge is cold enought so it stops. And when it warms up a little it should automatically start working again.
The dial changes the target temperature inside the fridge.
So when you lower the number it keeps the fridge a little less cold.
  • Ekse Mar 10, 2008
    Yeah and unfreezeing the fridge would be a good idea to do atleast ones a year. Thats should fix it like The machine said.
    Master:
  • 788 Answers
I would assume that a thermistor or thermistat is faulty and so the fridge is not detecting it's temperature properly. Try removing the cover around the dial and remove any ice covering the components. Otherwise, empty and unplug the fridge and let the ice melt and the components dry then see if the problem is resolved. Good Luck!
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a 20 year old side by side sub zero. For the last few months i have had problems keeping the temp even in the refrigerator side, either freezes or gets too warm. Now it wont get colder than 45 or...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Sub-Zero Refrigerators
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
