I assume that you are referring to a ducted central split system. If so, if the whining sound is coming from the return air grille that is an indication that the ducting may be undersized, or you have a restriction to flow back to the furnace or air handler, that could also contribute to the temperature setting not amtching the indoor temperature and allowing for improper run times and requiring a higher setting on the stat to allow for a long enough runt ime to stisfy the temperature setting. Check your return ducting to verify it is not collapesed or if it is insulated internally that the insulation has not come loose and is blocking the airflow. Hope this helps!
Dan
