Question about Singer 7436 - INGENUITY
The stitch is backwards...
When i change the thread on my machine suddenly what is meant to look like the back/wrong side of the stitch is actually on the top of the fabric and the 'right' side is on te backside of the fabric....why?????
please help me!
i have a singer 7430 and it's doing the same thing...but also in the bobbin thread color and not the top thread color. what the heck??
i have tried messing around with all of the top thread tensions, but that hasn't worked.
  • Singer Master
  • 1,388 Answers
My best guess is that you both need to look at the bobbin tension, but this article will outline how to achieve the correct balance for top and bottom tensions Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
the stitch is backwards... - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 14, 2008
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Skipping Stitches My Singer Confidence machine is skipping stitches. I've cleaned the feed dogs and the stitch hook, changed needles three times, changed thread, adjusted the tension, etc.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Oct 07, 2013 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Machine is skipping stirches
Skipped stitches
Sep 17, 2012 | Sewing Machines
Sewing machine not stitching
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
Singer Confidence 7463 - needle is knocking - bobbin wont thread...machine doesn't stitch - not even 2 months old
Have you changed the needle since you purchased it? A needle should be replaced every 4-6 hours of stitching so for each garment sewn as a rule of thumb. So try replacing the needle, cleaning and oiling the maachine as per the manual. Check needle is in the correct way, it is easy to put in backwards if you aren't familar with them, flat shank to the back and there is usually a scarf (cut away area) at the back of the needle which is where the rotary hook under the needle plate comes around to catch the upper thread during the stitch process. So if needle is in backwards this will cause stitching to fail.
So elimate the needle firstly.
If this fails and the knocking noise continues, then it could be that the timing has been knocked out. It can happen if you sew over a pin and hit it hard (or the needle strikes the foot if stitch setup is wrong for the foot being used). In this case, you'll need to take it back to the shop for the serviceman to fix.
Mar 02, 2011 | Singer Confidence 7463 Computerized Sewing...
Loops cross over on both sides - wavy pattern develops
Several things may be causing this.
First, make sure that the wire rack is DIRECTLY above the cones of thread (it may be backward). The thread must come straight up from the cone as it pulls off. Not coming straight up will cause a wavy stitch because of the thread dragging on one side of the cone.
Make sure that the threads are fully pulled into the tensioners, not riding on top of the discs.
Inspect the needle plate and ensure that the stitch forming pins and or fingers are intact.
Aug 18, 2009 | Juki MO-644D Mechanical Sewing Machine
Stitch pattern is wrong
Here's the manual,
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lets see if we can do some troubleshooting.
Have you checked your needle (size, for thread your using, material)
It sounds like a tension/settings issue, but could be as simple as poor thread quality. try changing the thread, and rewinding the bobbin. If using a silky material remember you need to back that up and make it stiff.
If this and a resetting of tension doesnt work,
Check your left side right side balance (pg 57)
Check page 84 on trouble shooting
Jan 27, 2009 | Singer 3116 Simple
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Singer 7436 - INGENUITY Logo
55 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
