Question about Sewing Machines
Kenmore model 158-12392
The sewing machine will come on but it will not make a mechanical connection to run the sewing machine? The wheel turns and the belts are okay. I take off the wheel end and the wheel is turning properly but what ever makes the connection mechanically is not happening? lost
  • Sewing Machines Master
  • 1,388 Answers
It is a clutch issue.
If you can turn the handwheel manually and the motor belt is running OK but the needle will not move, you will need to check the clutch mechanism for the bobbin winder.
There are three ways for the clutch to engage, and as I do not know your machine, I offer all three for you to see which applies to yours.
Flick winder to the left to engage needle arm motion.......it may activate automatically when the winder is set to wind a new bobbin and de-activate the needle arm
or
there may be a small wheel inside the larger handwheel....tighten the inner wheel to engage needle arm...
or
the handwheel may have a push/pull action ....push in to activate the clutch, pull out for bobbin winding.
If there is any more you need to ask or update your info to refine the question, just post back here, or drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 14, 2008
Kenmore sewing machine, Model no. 13550
It needs cleaning and oiling! Do NOT run the motor until you get it taken care of or it can damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Nov 22, 2017 | Kenmore Sewing Machines
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Hums but doent want to go
Check the features for bobbin winding and make sure they are not activated.
If this model has a smaller wheel in the center of the hand-wheel, make sure it is tight (turn to the right, or to the back of the machine).
Mar 06, 2010 | Kenmore 11101 Mechanical Sewing Machine
Bobbin winder does not work on Model 17651
Make sure that the hand wheel is engaged by pushing it in. To disengage, pull it out.
Feb 03, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
219 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
