Won't Spin Without Assistance
The washer goes through the motions - filling, washing, draining - but doesn't spin unless I open the lid and help turn the basket. Once this is performed the spin cycle continues.
Kenmore 80 Series Model 24812200
  • Shawanba Mar 10, 2008
    I washed a very small load today. The first spin cycle went through okay, but the second one didn't. How can I access whether the clutch mechanism or gearbox isn't performing and can I replace it myself?
    Novelist:
  • 142 Answers
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Posted on Mar 10, 2008
  • Ray LeBlanc Mar 11, 2008
    I admit I haven't had to do this before. I'd go after the clutch mechanism first. Since you made no mention of strange sounds during the spin cycle and the basket does indeed spin, chances are the gearbox is fine.
    If I were in your shoes, I'd look around for the item by calling the manufacturer and get a price. Consider the age of the machine and the cost of a replacement machine. It might make better sense to replace the machine with one that has a warantee. If something like this is going wrong, it might just be the start of a series of problems. good luck!!
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Washer won't spin or drain
if it can't drain then it won't spin,something could be jammed in the pump,the clutch isn't falling on the trans. what does it do when it goes into spin cycle'do you hear any noises.when it does go into spin cycle listen if nothihng hapeens open the lid and close it listen to see if the clutch falls
Mar 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSQ9544KQO won't spin
if it fills with water and then nothing check the lid switch,if it's bad it won't do anything but fill,some will agitate but then no drain or spin,the easiest way to check it is open the lid a few inches and close it,do this a few times,if you don't hear a clicking sound the switch is bad,or open the lid and stick a screw driver into the hole on the right side where the strike from the lid goes into,if it doesn't click when you push it down and let it up it's bad,part number 3949237 and it's around 50 dollars.watch this video,it's a different lid switch but changes out the same way.
http://www.youtube.com/watch?v=MFsvLiuTniU
you can also stick a jumper wire into the two outside wires to check it,flip up the top console,you'll see the lid switch connector on the right side plugging into the top of the frame,unplug it,stick the jumper into the connector that unplugged from the frame and it will have three holes in it,the middle is ground so stick the jumper into the two outside holes,set the timer to drain and pull out the timer,if it starts to drain and spin then you know the lid switch is bad.hope this helps.
Jun 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
