How to remove the back off a toshiba laptop - Computers & Internet
  • lyndsey1985 Mar 10, 2008
    the model is satellite A60 106.
    i am trying to remove the cd/dvd drive to try to clean the gold connector .what is the easiest way to do this
    Problem Solver:
  • 10 Answers
What you mean with the back? And What model its your toshiba?
Posted on Mar 10, 2008
  • Djupdown Mar 12, 2008
    I opened a similar one yesterday. You have to take out the keyboard. But is going to be hard if you dont know. Look for a tutorial that explains you how to do it. In this laptops you always have to lift up a piece that is just upon the keyboard. Looks like it had been made to do this. Figure it out. It will take you some time but if you do it carefuly youll open it right. Trust me.
    Good Luck
How to Remove my Toshiba Satellite C55D Laptop Keyboard
ok
1. first remove your laptop battery
2. then see the back side
3. then remove keyboard scrove
4.and remove your keyboard.
Apr 27, 2014 | Toshiba Computers & Internet
Broken Laptop Screen: Toshiba Satellite c670-165
As in this model?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/remove-replace-screen.htm
The Display Assembly is laid back to a point, that you can access the two bottom screws. Isn't a direct 90 degree position with the screwdriver. More like 60 degrees.
No?
Then the Top Cover (Palm Rest Cover) has to be removed, in order to access.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/remove-replace-lcd-screen-inverter-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Don't forget to remove ALL power. AC adapter and Battery.
Regards,
joecoolvette
Jan 13, 2013 | Toshiba Computers & Internet
How do i remove the cd dvd drive
Turn off the Toshiba laptop, remove the AC adapter and any other peripheral devices, and close the lid.
Turn the laptop over.
Touch an unpainted metal surface to discharge any static electricity. Release the battery lock-usually located near the back of the laptop-and remove the battery from its bay.
Remove the screw holding the DVD drive in place.
Where the screw is located depends on your Toshiba's model, but in newer laptops-particularly the Satellite-the screw is located next to the Toshiba sticker.
Unlike the other screws, which are embedded into the laptop, the DVD screw is even with the rest of the laptop's surface.
Gently pull the DVD drive from its bay to remove it from the laptop
hope this helps
Sep 13, 2012 | Toshiba Satellite P505D-S8935 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
