Question about Linksys WRT300N Wireless Router
Linksys Wireless N adapter Missing Hardware.ID
I have an N Linksys router, my computer has intel proset in it, someone told me that in order for the router and the computer to communicate that I need to get an N wireless adapter, so I did, but the N adapter stayed inactive, so I tried to uninstall it but I get (an installation support file could not be installed, the system cannot find the file specified)
Hopefully someone can help me with this
Thank You
Kathy
  • 1 more comment
  • KathyC143 Mar 12, 2008
    My operating system is xp.
    No I don't know how to configure the settings
    Thanks
  • KathyC143 Mar 27, 2008
    The N adapter won't work at all, it is in the bottom tray and says its inactive also I have intel proset that came with my computer, I was using a g router with the intel proset until someone told me that if I upgraded my router to an n that I would have faster speeds, I installed it and the intel proset is picking it up and not the n adapter, also someone told me that I have to have an n adapter to talk the same language as the n router. I'm completly confused.
    Thanks
    Kathy
  • Raymond Roque
    Raymond Roque May 11, 2010
    Hi Kathy,
    What is the operating system of your pc? (xp or vista). if your pc already has the intel proset then you don't need to install the wireless N adapter. You just have to make some settings on the router. Do you know how to access the configuration page of your N Linksys Router? i'l be able to give you the exact solution if you can give me answers to these questions.
    Regards
    Scholar:
  • 141 Answers
Hi Kathy,
Please do this first. go to control panel>add/remove programs, uninstall the Linksys Wireless N adapter.DO NOT UNPLUG THE WIRELESS ADAPTER FROM THE PC. Insert the Linksys wireless N adapter cd(DO NOT RUN THE SET UP). If the set up wizard shows up CLICK exit or cancel.Restart the pc with the disc in and the wireless adapter connected. When the pc boots up you will see the found new hardware wizard. Continue with the wizard, Select No not this time, Select install software automatically. If this is successful, your pc should be able to detect your wireless network
Posted on Mar 12, 2008
My everex stepnote laptop will not connect to the internet per wireless now. Will connect via cable. See all wireless connection, but just continue to search and search and fail cnnection. Error message...
You may have a driver problem. First, simply try to set up a new wireless connection. If that doesn't work, try this.
While hardwired go to:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
(just copy and paste into address bar of browser if necessary, or type it as one long string.
Under "products" choose "wireless networking". Under "Operating System", find your specific O.S.
Under "Download Type", choose "drivers". Then scroll down to find the drivers you need.
Download and install the driver package
If this doesn't work, repost with more information concerning the make, model of your computer, type of operating system, and be very specific. Give as much info as possible
Installation instructions:
Immediate Installation/Upgrade of Drivers on Local Machine
To install or update on this machine now, click 'Install Now' below or use standard OS installation methods
To Install or Update Later:
1. Click Start, Run and then browse to the directory where you extracted this archive.
2. Double click Setup.exe and click OK. Follow the on-screen instructions to complete the install.
3. Right Click on "My Network Places, Choose properties and finish configuring your network.
Manual installation:
1. Click the My Computer and choose Properties, From Hardware tab, choose Device Manager.
2. Right click on Network Adapters and choose scan for hardware changes.
3. The Plug and Play Wizard should pop up. Follow instructions but don't select an Intel adapter from the list. Click on Have Disk.
4. Enter the path to the directory where you extracted this archive and click OK. Then follow the instructions to install the drivers. When the adapter is added, it appears in the Network adapters list.
5. Click OK and then Close. If prompted, restart Windows.
Optional Manual Update
2. Right click on the adapter you wish to update under Network Adapters and choose Properties.
3. From the Driver Tab of the pop up, click the Update button.
5. Follow the on-screen instructions to update the drivers.
NOTE: If you are installing a driver in a computer with existing Intel adapters, be sure to update all adapters with the same new software. This will ensure that all adapters will function correctly.
Troubleshooting
-Make sure that you use the drivers from this archive.
- When updating base drivers, if PROSet was installed, PROSet needs to be updated also. If you have downloaded the minimum Web Pak, you will need to download the full Web Pak to obtain the updated PROSet files before being able to access the PROSet application.
-In your computer's BIOS settings, make sure "Plug and Play OS" is set to YES.
-Make sure the driver is loaded and the protocols are bound.
-Check the Windows* Event Viewer for error messages.
-If you are attaching to a NetWare* network, check your frame type and verify that NetWare client or server software has been installed.
-Test the adapter with the Intel PROSet advanced configuration utility or with the DOS diagnostic provided in the Tools Directory contained in this archive.
-Check with your LAN administrator - you may need to install supplemental networking software.
Intel(R) PROSet II
To start Intel PROSet II, double-click the Intel PROSet icon found either in the lower right hand corner of the screen or go to Start/Settings/Control Panel/Intel PROSET II. To run diagnostics, select the adapter and click the Diagnostics tab, then click Run Tests. For additional information, click Help in the Intel PROSet window.
If this doesn't help go here:
http://www.piriform.com/speccy
Download and install the software. This will tell you everything you need to know about your computing environment that you will need to know to repost the question and get a definitive answer.
Open Device Manager (Start > Control panel > Hardware > Device Manager), look for anything that has a ?, or a yellow triangle w/an exclamation mark ( ! ). Make note of it in your next post.
Good luck
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you.
Nov 26, 2010 | Everex StepNote NC1500 Notebook
Needs almost daily rebooting to stay online. Often its just the wireless service between the router and the cable modem but the wired connection is okay. Often the wireless is connected to the router, but...
check if your computer uses other wireless utility (ex: intel proset wireless), if yes, uninstall it and update the wireless driver of your computer by downloading it from your computer's manufacturer's web site then restart the computer.
Jun 09, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Hardware.ID is missing warning
The Linksys might not be compatible with XP sp3. If it was working before, there is nothing wrong with your Linksys
Sep 10, 2009 | Linksys Wireless-G WRTP54G Router
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Intel Pro wireless 3945ABG cannot find available wireless network
Did u check if the wireless radio is enabled in the computer or not just make sure the wireless radio is on.....
1st check the hardware switch first....
on the front panel you will see a swith as well as the wireless card indicator for the wireless,just toggle the switch and check if the wireless inicator light is on and off incase the light is on and the switch is turned off do the following step...
2nd click on start go to all program,you will see intel proset click on intel proset and you will see two options now click on intel proset utillity,out here in this box you will see enable radio check if it says the hardware switch is on or off,if it is off choose the option to on and click on apply and ok and then check..
now you should be able to see the network as well as it should be connected to the network...
incase both the hardware as well as the switch was on let me kno what error is it giving while you click to view the network...
it might a possible thing that you need to reset the wireless card.....u might need to take the card in and out from the computer...
best of luck...
incase you are stuck let me know..
vedhick
Jan 31, 2009 | Intel PRO/Wireless 3945ABG Network...
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
I had the same problem. If you are using the latest driver for your intel 2200BG (9.0.4.7). Try to roll back to a previous version. It solved my problems with being unable to connect to a Linksys BEFW11 router running WEP64.
I am now running driver version 9.0.1.9
Oct 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys wireless g notbook adapter
From my experience with stubborn program removals, I go into regedit and search for all instances of the manufacturer name or related terms. Go to "Start", "run" and type "regedit" to enter the registry. Reboot system after changes are made. Have access to back-up easily available (how you do that is up to you). I delete those registery references. This has happened many times when I have uninstalled programs. That has typically corrected the problem. NOTE: please do this carefully, back-up the registry prior to monkeying with it. If you are not comfortable doing this then you are stuck or will need to take it to someone who knows.
Feb 10, 2007 | Linksys Wireless-G WRTP54G Router
Linksys WRT300N Wireless Router Logo
220 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
