Question about Acer Aspire 5610 Notebook
No audio and need power DVD software
No audio, i have tried to install it from my device manager and need power DVD software
    Genius:
  • 1,027 Answers
Try www.acerpanam.com
Click on the map of US
click on Drivers and downloads from left menu
click on notebook, select your model number, select your drivers or applications, e.g. realtek hi def audio
I can e-mail you power dvd with keycode(I have a spare Key on the e-macines tower sitting in the scrap heap)
Posted on Mar 10, 2008
Sound Won't play through Netbook
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 09, 2011 | LG Electronics 16x DVD and 48x CD-ROM...
I had to purchace a new OS (XP Pro) what I did not realize was that I had placed all my third party DVD software, Sonic My DVD, Sonic Digital Media, and the Roxio Easy Media Creator Suite, on DVD's. Now...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might have to install the burning software you used to burn the data to the the disc to be able to read you might have to copy the software to a USB drive if you can not read a cd/dvd
hope this helps
Feb 04, 2011 | Computers & Internet
My Sony CRX830E combo drive will not read any of the DVDs I have tried to play in it. The message it gives is that a compatible decoder is not installed. Is this a software issue, or do I have to buy a...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
Jan 02, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Hi my inbuilt mic is not working i belive it is
You must install the actual sound manager software. Just the driver is no good. You need something like Realtek HD manager or the like, You need the Audio package, with an Installer, install as Administrator too.
go to link below and download and install the Audio section again. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=99978&lang=en&cc=us&prodTypeId=321957&prodSeriesId=96403&taskId=135
Mar 07, 2010 | Compaq Presario 700 470024-192 Notebook
Fitted lg dvd drive to an acer netbook, playing DVD's there is picture but no sound. I've tried audio Cd in the drive and this works fine, any suggestions?
You have to troubleshoot your PC. Left click setting,
control, and the add hardware wizard. And follow the
instruction prompted by the add hardware wizard. You will be prompted to troubleshoot the Dvd hjardware and find if this working properly. You must also troubleshoot your audio drive. You can troubleshoot further by going to the Systems menu at the Control panel by left clicking on it, then Device
Manager. You will also see the devices installed in
your PC. Take attention to Sound, Video by left click
and right click to open and find the status. I understand that you have already installed the sound
driver software. If not, get your download at the Inter
net by the typing at the Search Engine blank (Download for Sound driver software) and left clicking
on it to go to the download site. Once your download
is completed,. have it installed in your PC. Hope this
will solve your problem.
Dec 02, 2009 | LG USB 2.0 Powered External Slim DVD?±RW...
Thanks for the response. I installed the audio cable but still no sound. Any other suggestions?? Checked the device manager and it tells me that the dvd is functioning properly.
First guess, ensure the speakers are powered, double check all connections. Ensure that all audio drivers are installed in the device manager, or try installing the drivers for audio from Dell's website. You can search via your Dell service tag to provide drivers for your PC.
Ensure the volume control for Windows is turned up and not muted, and ensure the volume on the speakers.
Are you trying to play an audio CD from the DVD drive? If so, it may require a 4 pin analog cd audio cable which goes from the DVD drive to the sound card.
Oct 31, 2009 | Dell Dimension 8400 PC Desktop
No audio on my newly installed xp software
If you can see an error in device manager its means the audio driver is not installed. You need to installed the audio driver. The audio driver is in the CD installer of your motherboard.
Regards
nicoleFIXIT
Oct 02, 2009 | Microsoft Windows XP Media Center Edition...
Need to get audio device back into computer
First you should check to see if the audio card is in the Device Manager. If not, try shutting down, unplugging power to PC open case (only if your comfortable doing so), physically remove the sound card and re-fasten it in the respective slot. Reconnect power and go into the BIOS. Once in the BIOS, get to the section of integrated peripherals, and disable the on-board audio. Save and exit, then let it boot up. If you get no "Found New Hardware", open the device manager and see if the card appears in the list. At this time if there is a question mark or an exclamation point, you have either a hardware conflict or an unknown device. If you don't have either of the symbols next to the audio card in the list, try opening your audio properties again and see if the card has returned to the software. If the device is not there, but is on the list in Device Manager, try re-installing the software it came with. If you have the other issues with the symbols and re-installing does not work, there may be something more than what may be the obvious.
Mar 11, 2009 | Computers & Internet
Dell Optiplex GX270 Driver Questions
On the Audio driver question: the answer is yes the Audio driver is what allows you to have sound.
On the DVD software, I did not see any software on Dell link. Download Windows Media, newest version is ver.11
It will allow you to watch DVDs
You can also check this site:
http://www.dvdsoft.net/modules.php?name=Downloads&d_op=viewdownload&cid=1&orderby=titleA
Copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | Dell OptiPlex GX270 PC Desktop
Acer Aspire 5610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
