Question about Lexmark P4350 All-In-One InkJet Printer
My printer does not print smoothly.
The end product, in areas is like it is smeared or double printed. It is almost like the printer is jerking while the paper is being printed. I cannot print any papers for anyone as they are very poor quality. Any suggestions.
Cheri'
    Genius:
  • 2,035 Answers
Step Action
1 Power the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Gently move the cartridge carrier into a position where cartridges can be removed.
4 Remove the print cartridges.
5 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
6 Repeat Step 5 for the other cartridge slot (if applicable).
7 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
8 Plug the printer/All-In-One back into the power outlet and power it back on.
You should only follow the steps below to resolve a print quality problem if you have already attempted to solve the problem by printing a "Clean Print Nozzles" page. On all recent Lexmark Photo Jetprinters printers, this option is available under the Maintenance tab of the Lexmark Solution Center. On some Lexmark AIO Photo Jetprinters, you can also find this option in the operator panel menu and also page to pint alignment page please perform test...
Cleaning procedure
Important remove all excess water and wet the copper contacts ,check for the print nozzles with dry paper (ink is left on the paper)
Moisten a clean, lint-free cloth with water.
Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
With another clean section of the cloth, repeat steps 2 through 4 above.
Allow the nozzles and contacts to dry completely.
Reinsert the print cartridges.
Print the document again.
If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
Posted on Mar 11, 2008
    Problem Solver:
  • 10 Answers
Try changing the ink. Or maybe its the drivers. Check in lexmark website for updates.
Good luck
Posted on Mar 10, 2008
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
RICOH 1224C COPIES ARE SMEARED
Smeared output can also result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
If this does not resolve your issue then make sure the fuser is heating; if not, the thermostat is bad and you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
May 12, 2010 | Office Equipment & Supplies
When documents print out, one side of the copy is smeared. We cleared out a paper jam and I think part of the lining of the roller came off.
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Mar 29, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
BAD, BLURY, SMEARED, PRINTING
This is from the lexmark website
"Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected."
Oct 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
