Question about Kitchen Ranges
Range control panel
Electronic clock and oven control went bonkers after a power outage.
I can't reset the time or oven temp. I shut the breaker off and on but it didn't help.
Any help would be appreciated.
thanks!
  • cjoey Mar 10, 2008
    How do you do that?
  • Anonymous Sep 21, 2008
    power outage don't know how to reset the hour
    Novelist:
  • 131 Answers
Replace the electronic clock.
Posted on Mar 10, 2008
  • Michael Grimshaw Mar 10, 2008
    Sorry, I've done it a hundred times, and forgot that most people haven't.
    Unplug the machine, remove the back cover behind the console. There's usually four screws holding the clock to the console. Unplug the connectors one at a time and replace them on the new clock. Remove the old clock and ***** down the new one. If you didn't buy a clock overlay, you may need to gently peel the overlay from the old clock and place it on the new one.
FGGS3045
Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Mar 08, 2014 | Frigidaire 30" Slide-In Gas Range FGGS3045
Range control panel
Instructions on how to setup the clock
If the front side the oven has melted so that you are unable to do this.
Then the plastic cover would need to be removed, I beleave the buttons would still work without the plastic cover, but I do recommend geting this serviced by a professional but if you must get it to work right now.
I don't have a service manual so I dont know exactly how to remove the cover.
Apr 20, 2008 | Rangemaster 110 (Gas) Kitchen Range
Frigidaire GAS range
Hi Jo, thank you for your question! Let's try resetting the appliance by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back. If resetting the power does not correct the issue, your range could possibly have a faulty EOC (electronic oven control) or a potential wiring failure. I would suggest contacting an experienced service technician to determine the precise cause to reduce the risk of unnecessary parts.
Jul 25, 2013 | Frigidaire FGF368GC Stainless Steel Range
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
We had a power outage and when the power came on the oven says it is locked but is not latched and will not clear. Randy
If you cannot clear the display with the reset/clear button on the range control panel, go to your electric panel and trip the breaker for the range/oven for at least 2 minutes, then turn the breaker back on.
Sometimes when power is lost due to a storm outage, the drop in voltage can cause some of the electronics to act funny and "think" certain buttons were pushed. Simply turning off and back on the power at the panel should clear any minor problem.
If this doens't clear/resolve the problem, it is possible that the electronic controls were damaged and a replacement control module is needed.
Try the easy fix first and see if that helps.
Jul 28, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
The electronic oven control my whirlpool GS470LEM is blank.
Check the breaker to see if it is tripped turn it off and back on,
Jun 01, 2009 | Whirlpool GS470LEM Gas Kitchen Range
Oven burnout
replace the oven control
Apr 25, 2008 | Kitchen Ranges
Kitchen Ranges Logo
261 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
