Back to:
Tags:
Casio Exilim Zoom EX-Z700 Digital Camera
Need Help!!! Please...
posted by Spyke_hon on Mar 10, 2008
Hi - My Casio Digital Camera EX-Z700 has a problem. Whenever I take a picture, the image comes out with white lines across it or if I take a picture outside in the sunshine or in a bright area, the entire picture comes out white - there is basically no distinguishing figure in my photos - it looks like I took a picture of bright white paper. When you look through the viewfinder, or record a video the lines aren't there. What is wrong and how can I get it fixed? Please help me!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 19, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem.
When I put some zoom (a half of optical) the problem goes away... It´s not a solution, but, can save some time to buy another camera (or find a solution)...
I hope this help you
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Need Help!!! Please...:
I don't want to Accept this solution
Solution #2
posted on Apr 03, 2008
Not Rated (0)
mcomijohns
Rank:Wiz Wiz
Rating: 85%, 203 votes
Sounds like a setting try setting it to default un the setup menu if that does not help then the CCD need tobe replaces most likely. Hope this helps.
Thank You!
Can you Help with these Digital Cameras problems?
Hello, I'm Kento from the states. I purchased the CASIO...
I was using my camera then I turned it off and set it down...
I remember when I was researching the Casio camera it said...
hi my exilim ex-z700 just stopped working lens...
When I turn on my camera - Samsung Digital DSC T7, the...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
