Question about Daewoo DTQ-25S3FC 25" TV
Horizontal screen size
When watching certain channel cant see banners at top or sports shows wit scores. can this be adjusted
    Problem Solver:
  • 20 Answers
Will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Posted on Mar 17, 2008
Vizio tv settings
Check your aspect setting; ie: picture size, zoom settings
Nov 28, 2013 | Televison & Video
Cannot see score bar at top of screen during NFL games
Try operating on screen adjustment command, if there is no way to adjust screen position , then it may be a faulty component inside the TV.
Is the tv still under guaranty?
Sep 07, 2008 | Sony Grand WEGA KF-50WE620 Television
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
I cant see the bottom or top of my show
Push the View Mode button on ur rmote.Pick the mode u can see the whole screen.
Feb 15, 2010 | Toshiba REGZA 47HL167 TV
Samsung 650 LCD picture is cut off top and bottom
select the correct tv format, check your manual
Jan 01, 2010 | Samsung LN46A550 LCD TV
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Daewoo DTQ-25S3FC 25" TV Logo
214 people viewed this question
Top Daewoo Televison & Video Experts
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
