Washing machine won,t fill
  • robbie12 Mar 13, 2008
    earth fault on motor was found to be the problem and am now going via trading standards as machine is only 15 months old. thanks for any help and hope the above can be of use to others. rob
Check filter and also check inlet vaulve
Posted on Mar 10, 2008
Washer will only fill slightly on rinse cycle and not at all on wash cycle
Is the water on? Does the pump run when emptying machine? If yes to both, try running the machine through a spin cycle if you can and let it finish on its own. The valve should close and allow it to fill. Also, top or front load washer? ... These may help How to Fix Washing Machine That Won Fill With Water DoItYourself com
Jul 17, 2018 | Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Washing machine won't fill
What is the model number?
Oct 21, 2012 | Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
110.26822690 Washer won't fill...can't get back off to check the problem.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 09, 2011 | Kenmore Washing Machines
It won't fill . the water on. the dryer works but no power going to the wash machine??
heatman101
Jun 21, 2011 | Frigidaire FLEB8200DS Top Load Stacked...
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Open Questions:
Washing Machines Logo
242 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
