Question about Gestetner DSm635 Copier
How to Network the scan function of a Gestetner DSm635
I need to network the scan function of a Gestetner DSm635 grayscale printer/copier/scanner to an office of computers. This machine is already networked to print. My IT department told me that networking the scanner was not possible which doesnt make any sense. How can I network this scanner.
Please help,
email: erinjhayes@gmail.com
Most IT departments don't know how. They won't admit that but it is true. You already print to the thing so all that has to happen is setting up SMB shares on the computers and telling the scanner where to scan. Your very best option would be to contact your printer repair company and ask if they have a connectivity or networking specialist that could help you. If they are a good company they may even call your IT people and help them help you. And of course nothing technical comes for free.
I hope that helps.
Posted on Apr 08, 2008
    Problem Solver:
  • 8 Answers
The only real problem would be finding the software driver for your machine.When your driver for your scan function is loaded it will assign an IP address for the scanner.without the software,your out of luck.I'll look online tonight for it and let you know if I find it.
Posted on Mar 10, 2008
Laserjet m1136 mfp
Have you considered installing the scan tools on the other computers? Print sharing is a function of windows; assuming that the printer is not a true network printer. Windows does not have the ability to share scanners. But this is where the software can scan the network and find a HP scanner. Also some scanners can perform a "scan-to" function; but I believe the software need to be installed on the destination computers for this to work as well.
Dec 11, 2013 | Office Equipment & Supplies
Hello i need scanner driver and utility
I dont have much experience with this model. But i think you dont need any driver for scanning.
Use the network. It is much easy for you and for all users.
Creat the users and you done
Feb 26, 2011 | Gestetner 7502 Digital Imaging System...
Our Gestetner DSM635 jams every time we try to staple copies. Researching this issue, I saw that we need to initialize the staples by going into the Tools screen. However, when I try to do this, that...
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving
Jan 26, 2011 | Gestetner DSm635 Copier
We have two copier canon iR3225 and iR2022n. We got problem in scan in server2003 software while colour scan gear is installed. Server2003 is not detect the scanner.
Is the copier connected in the network or thru USB? Because Colour Network ScanGear is used when copiers are connected to the network.
If it is connected to the network, run Network ScanGear Tool and search for connected scanner in the network. Or you can use the IP Address of the copier to find it on the network.
Use 3rd party software or any other software that have scanning/import function (e.g. Photoshop).
Aug 11, 2010 | Canon imageRUNNER 2270 Copier
How to install the scanner
use the scanner manual. It slides in to the board on the side of the machine where you printer and network connection are. Turn you copier OFF and unplug. Remove the screws from the print card unit unit on the machine where the network cable connects. you need to have the machine set up as a printer before you can install scanning. The scan card slides into that board
Mar 28, 2010 | Gestetner DSm615 Digital Imaging System
Trying to hook up a gestetner dsm415pf directly to a laptop so the scanner will work. The printer already works fine
pf stands for print/fax. As far as i know it should not be able to scan but you can try the twain driver using a network cable.But don't think it will work.
Jan 31, 2010 | Gestetner DSm415f All-In-One Laser Printer
Hi! My matchine is scaning all documents in Grayscale by def
yep!
sorry but our panasonic dp-8035 is only black&white document scanner.
Jan 14, 2010 | Panasonic DP-8035 Grayscale Copier
Gestetner 2712 as a scanner
Yes they can.
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Gestetner 2712 Digital Imaging System...
Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
Jan 22, 2009 | Gestetner DSc224 Copier
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
Dec 27, 2007 | Gestetner DSm618 All-In-One Printer
Gestetner DSm635 Copier Logo
581 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
