Question about Quest Software Spotlight On Windows (WIN-SPO-PB-TRA) for PC
Error with tnsnames and oracle install
When I go to execute spotlight i keep hetting this error: Therre was an error in reading the tnsnames.ora file. Either oracle is not installed or the tnsnames.ora file is corrupt. I have uninstalled/installed both oracle and spotlight and checked my path, but still receiving the same error. I have also copied exact tnsnames file that works with oracle's sql plus. Any ideas why this error occurs?
Re-install MSXML 4.0 SP2 Parser and SDK package.
- MSXML 4.0 SP2 can be found at http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&DisplayLang=en
- SDK package can be found at http://www.microsoft.com/downloads/details.aspx?FamilyId=A55B6B43-E24F-4EA3-A93E-40C0EC4F68E5&displaylang=en
Posted on May 29, 2008
Incorrect number of bytes written to disk
A search of the Oracle Metalink site ( http://metalink.oracle.com/ ) for the ORA-27063 and ORA-19502 errors returns Oracle Document ID 271511.1. This note indicates the hard drive of the Oracle server is full.
Resolution:
Free up disk space on the Oracle server. Refer questions regarding the correct way to clear files from the Oracle server to Oracle support.
http://www.symantec.com/business/support/index?page=content&id=TECH38253
Apr 15, 2015 | Computers & Internet
I am getting an oracle error while trying to login. The error says: ORA-12545; Connect failed because target host or object doesnot exist. What could be the probable error?
ORA-12545: Connect failed because target host or object does not exist Cause: The address specified is not valid, or the program being connected to does not exist.
Action: Ensure the ADDRESS parameters have been entered correctly; the most likely incorrect parameter is the node name. Ensure that the executable for the server exists (perhaps "oracle" is missing.) If the protocol is TCP/IP, edit the TNSNAMES.ORA file to change the host name to a numeric IP address and try again.
Aug 16, 2010 | Computers & Internet
Problem installing the ORACLE on ACER Altos G510
may be u require a different version?so download it
Mar 17, 2010 | Acer Altos G510 Server
Orcale problem ?
This is an Error generated by the Oracle Client when the Oracle Server can not be reached.
This error can be caused by several items:
The Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator
The network connection to the Oracle server is not fully up and running. Check all connection points between the Notes server and the Oracle Server
A firewall exists between the Notes Server and the Oracle Server, and is not configured to allow access to both the Oracle Server's IP address and Port
The ADDRESS Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on Oracle 8.0.x) to check the connection to the Oracle Server. Example of a successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on 23-APR-99
10:24:39
Attempting to contact (ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521))
OK (50 msec)
If this is Not successful, check your Oracle Network Products Messages Manual to resolve the errors that TNSPING points out.
well i found this from one site .... hope u can read it and can solve your problem
Oct 14, 2009 | Computers & Internet
Strtdb80.exe
First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Regards,
Mar 27, 2009 | Microsoft Windows XP Professional SP2
Vb 6.0 to oracle connectivity problem
Your SQL query does not look valid. Test the query in SQL Query analyzer, and then once it is working, copy it into your VB source. You will of course then need to make the query a string that VB will accept.
Mar 23, 2009 | Microsoft Computers & Internet
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Quest Software Spotlight On Windows (WIN-SPO-PB-TRA) for PC Logo
1,104 people viewed this question
Top Quest Software Computers & Internet Experts
DavidBHill
DavidBHill
Level 1 Expert
Are you a Quest Software Computer and Internet Expert? Answer questions, earn points and help others
