I have not been able to get the audio to work---it beeps at the bootup and hdd password screens, but I can't get a peep out of it in windows. What the heck is a "base system device"? whatever this is, may be my problem because I don't know what it is to install it. I tried trial and error, but the "wizard" only wants to go online, and doesn't find anything if it does (aka useless wizard).
Also, I can''t figure out what multimedia controller to install, and "help" is no help. This laptop has been pretty solid for me since fixing the power connector problem, all I need is to identify this base system device...anyone have a clue?
Comments:
Mar 11, 2008
- I reopened the casing and checked every connector of any stripe I could find, and still no sound other than the system beeps that tell me the speakers themselves are operational. I may have to wipe my hard drive clean and start over. I have an I/O conflict though, I just don't know what to do because the option to change the address isn't available for that device. Suggestions?
Mar 12, 2008
- Hey! I didn't even notice that. (not that I would know what I was looking at anyway).
I'll check that out. I have some speakers from scrapped out laptops around here, if I find some that will fit and have that same plug on them, is there any reason I can't replace them?
Also, I forgot to ask what would be the problem since headphones or external, amplified speakers don't get sound either? Drivers, maybe?
base system device could be the audio on the motherboard or the audiocard itself. go to the page that has system devices and find your audio and supported devices and see if the latest driver is available. when you repaired the connector, I take it you had to pretty much remove everything to get to the board connector. could it be you didn't reconnect a connector? those thin film flat cable connectors can be a pain.
Comments:
Mar 11, 2008
- the motherboard has a solid state mini speaker on it and operates off the windows program. the main sound is an audio card. could be it's loose in its socket. or just plain burned out.
On my Compac Presario R3000, the L.E.D.'s that indicate caps, wifi, touch pad, and number lock...
(More)
On my Compac Presario R3000, the L.E.D.'s that indicate caps, wifi, touch pad, and number lock either light dim or are out most of the time, if i tap lightly next to the touch pad they come on bright for a while, where can i get info on the power path for these lights, i know how to disassemble and solder etc. I am a tech who repairs small SMD circuits. I have looked internally for a broken connection and haven't found it. Thanks, Lee P.S. Ya, fixed the power jack a few times, crummy design!
sound coming from laptop speakers and headphone at same time on compaq presario v3000 with xp. cpu...
(More)
sound coming from laptop speakers and headphone at same time on compaq presario v3000 with xp. cpu was recently formatted and xp re-installed
On my Compaq presario R300 laptop the following keyboard malfunction is present.When this @ key is...
(More)
On my Compaq presario R300 laptop the following keyboard malfunction is present.When this @ key is used it shows as " Can you help?
