troubleshoot motherboard
Back up everything possible on your hard drive.
If you're experiencing hardware issues, this is a luxury you might not have.
Keep backup files on an alternate data storage system to avoid data loss during hardware problems.
Notice the issue and reproduce it so you're aware of where the symptom manifests itself.
Isolate the problem.
If the system isn't getting power, make sure it's not the power cord or wall outlet before you try a different motherboard.
If everything is trying to run but not actually able to, check for loose parts on the motherboard before you replace it.
Remove all of the hardware that isn't actually necessary to make the computer function before you can narrow down the causes for your problem to the motherboard.
Ensure that all cards and memory units installed on your motherboard are securely in place and that each is making a good connection.
This can be accomplished by removing each component, blowing out the socket with compressed air and replacing the components.
Try another compatible motherboard in your machine once you've eliminated all other potential problems.
If it works with the alternate motherboard, replace the old one.
hope this helps
I already have a 60gb. Will adding an 80gb be okay?
