-   my zanussi zwf 1421 will only make a noise for 1 second on any setting and wash program. I have cleaned the pump and filter and mains water filter, cold water supply is fine and dicharge hose is clear. Have cleaned soap tray and it's recess and have also tried by-passing the door switch in case that was the problem. Am still waiting for an engineer to call so hope someone can help. thanks. Rob-   robbie12
Are there any new washing machines made that still have direct drive. That means that the agitator...
(More)
Are there any new washing machines made that still have direct drive. That means that the agitator has two pieces and is not just one part. I told my repair man that my dad had been in the appliance sales and repair for over 50 years before he passed away and he said that normally he doesn't tell people about the new washers as they would be too depressed to learn that they are all garbage. I forgot to ask if him if anyone still makes them with direct drive.
my kleenmaid brandt 5kg washing machine has had a new motor and now has a bumpy sound or knocking...
(More)
my kleenmaid brandt 5kg washing machine has had a new motor and now has a bumpy sound or knocking sound when washing what could be the trouble? regards Dyan
error code f06 code shows up, unplug the washer and let sit for 5 minutes and plug back in and the...
(More)
ERROR CODE F06 CODE SHOWS UP, UNPLUG THE WASHER AND LET SIT FOR 5 MINUTES AND PLUG BACK IN AND THE WASHER WILL COMPLETE A COUPLE OF CYCLES BEFORE IT FAULTS AGAIN. I called whirlpool and they claim no service manual is available from them. (I doubt that) the help desk indicated it was a communication problem. My searching of the web would lead me to beleive the problem is in the communications to the MCU. does anybody have anybody have a similar experience with the problem?
Older Kenmore 90 Washing Machine suddenly began stopping after first wash cycle in permanent press...
(More)
Older Kenmore 90 Washing Machine suddenly began stopping after first wash cycle in permanent press or heavy duty settings. Normal setting seems to work fine. NOT timer, just replaced that and no change. Don't hear pump trying to drain it.
