Question about Sony XPLOD CDX-GT200 CD Player
No display on front pannel
It receives cd, ejects also but there is no dislay at all on front pannel please help
  • 1 more comment
  • Anonymous Mar 20, 2008
    Have the same problem nothing on the led, but the cd is recieved and can be ejected, a how to fix this problem solution would be appreaciated
  • hoserboy Aug 07, 2008
    when i first hooked it up it worked.when i removed dash to install bracket (chevy silverado) does not work. does the same thing now as the other guys.
  • MrsCB Oct 16, 2008
    I installed my Sony XPLOD CD Player, I know everything is connected properly. There is power, it will accept CD's and eject them but there is nothing coming up on the display. No lights, nothing.
I had this same problem. I solved it by connecting both yellow and red power supply cable coming from player to only yellow cable from my car. There was also red wire coming from car but things didn't work that way. I can't say I knew what I was doing so try on your own risk.
Posted on Apr 25, 2008
  • 129 Answers
Check on the ac supply for the filament of the display from the power source and also check for the cold solder along the terminals of the LCD. also, I need your reply if your unit can read.
chris
Posted on Mar 10, 2008
A cd broke inside my dvd writer while using it, and now it wont eject
on the left side of the front pannel just under the drawer you will see a pinhole.turn your cd unit upside down and insert a straightened paperclip in the hole keeping it straight as possible,the drawer should open enough to allow you to grip it .
if no luck you will have to remove the case top and manually remove the disc..
hope this helps.....Len..
Jan 13, 2014 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Theirs power to the internal eject but not on
tie your ignition wire on your battery it should turn on if it works tie the ignition wire into the fuse pannel 10 amp if you have one
Jan 09, 2010 | Kenwood KDC-3028 CD Player
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
CD ROM has disk but this will not eject - there is no little pin hole on the vostro 1710 anywhere, nor does hitting eject from the Bios screen work....
Cd-rom will need to be extracted from unit the pinhole is lickly on the back of the unit most are. good luck please do leave postive feedback ether way for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | Dell Vostro 1710 Laptop
LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Jan 08, 2009 | Car Audio & Video
Not turning on
That Red light is saying that the front panel is not attached. This is the "Security Indicator" and is to warn crooks when you have removed the face plate. If this is on, and the plate is attached, I would remove and replace the front detachable plate once to ensure a good connection. That's a simple thing to try and only requires a quick operation.
Hope that helps. (If not, more info is needed for me to be of any help.)
Jul 22, 2008 | Panasonic CQ-C7103U CD Player
My fusion fcd 255
Hi G,
Do you hear any noise? like its trying to eject the disc? If you cant hear anything try using contact cleaner on the back of the faceplate, on the contacts. If you still cant hear anything, Id say the motors shot, and that not a self fix. By the looks of it, it seems like it just came out, if its still under warrenty, id exchange it for a new one. Good luck
CoDoc
Dec 11, 2007 | Car Audio & Video
CD will not eject
on the front panel, look for a tiny pinhole and insert a pin while powered up to reset the device, however it is possible your eject switch is inoperative now for some reason. if reset no-go, the disassemble the front panel, find the eject switch and clean the contact pads with alcohol swab
May 27, 2007 | Jensen MP6211 CD Player
Sony XPLOD CDX-GT200 CD Player Logo
199 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
