Question about Microsoft Windows Server Standard 2003 for PC
Hide drive how to hide a drive in windows like c:/ , d:/ any
    Master:
  • 478 Answers
I loved LEO Privacy. This app helps me to hide my secrets and when I uninstall it it gave me all my data back after installing again
Posted on Sep 27, 2016
    Master:
  • Microsoft Master
  • 615 Answers
I have had this same problem several times. Thanks to all who recommend me LEO Privacy, which is really great app to protect your images and photos even videos. https://goo.gl/BCKwGq%EF%BB%BF
Posted on Sep 02, 2016
    Master:
  • Microsoft Master
  • 381 Answers
Believe me friends, LEO Privacy is really an useful app.. It works nice and smooth... I can safe my private pics and videos and more specially i can lock apps as well.. Like face book etc.. Its great, grab it...
Posted on Aug 25, 2016
  • 4 Answers
You can use a software to hide a drive, saying kakasoftFolder Protector. I've used it for a long time. Hope this will do any help.Here is the link about it, you can get more information here:http://www.kakasoft.com/folder-protect/
Posted on Oct 12, 2012
Go to run type gpedit.msc
and select Administrative Templates under User Configuration.->Windows Components->Windows Explorer->Hide These Specified Drives in my computer->Right Click->Properties->enabled and select drive which u want hide.
u can also hide with the help of computer managment.
Posted on Mar 10, 2008
Tip
HOW TO HIDE UR DRIVE WITHOUT ANY SOFTWARES
<span><b><span>you can hide your "private" files using a nifty little registry hack that will completely remove an entire drive from your computer. The drive will not show up in My Computer, will not be accessible from the command prompt, and won't even show up in Safe Mode! Ok, so here's how to implement the hack: first off, back up your registry as this requires adding a key to the registry. Once you've backed up your registry, open the registry editor by clicking on Start, Run and typing in regedit.<br /><br />Now navigate to the following registry hive shown below:<br />HKEY_CURRENT_USER \Software\Microsoft\Windows\CurrentVersion\<br />Policies\Explorer<br />Right-click on Explorer and choose New and then DWORD Value.<br /><br />Name the new value NoDrives and then double click on it to open the properties dialog box. Click on Decimal for the Base unit.<br /><br />Type in one of the following values depending on that drive letter you want to hide.<br />Code:<br />A: 1, B: 2, C: 4, D: 8, E: 16, F: 32, G: 64,<br />H: 128, I: 256, J: 512, K: 1024, L: 2048, M: 4096,<br />N: 8192, O: 16384, P: 32768, Q: 65536, R: 131072, <br />S: 262144, T: 524288, U: 1048576, V: 2097152, W: 4194304,<br />X: 8388608, Y: 16777216, Z: 33554432, ALL: 67108863If you want to hide drive E, just type in the value 16. The really cool thing about this trick is the fact that you can hide multiple drives by adding the numbers of the particular drives together. For example, if you want to hide drive E and drive G, you would type in the number 80, which is 64 + 16.<br />Restart your computer and your drive will now be hidden! Trying to hide your system drive (C) will not work as Windows has to use this drive to run correctly, so don't store your secret files there!<br />When you want to get your drives back, change the value of NoDrives to 0 or simply delete the value altogether. Of course, having to do this everyday can be a pain, so if you're up for it, you can try and write a registry file that will allow you to insert and delete the value by just double-clicking a file.<br />This trick also works for mapped drives, so if you want to hide mapped drives, you can do it this way (though it might just be easier to disconnect a mapped drive).<br />Enjoy</span></b></span>
on Apr 04, 2011 | Computers & Internet
Tip
Important tips to Hide your Partitions and Drives
<p><span>How you can hide your system drives and from any other users. This technique is very useful when different users are using same computer and you want to safe your important drives by using this trick.</span><br /> <p><span>For that you can use windows XP TweakUI utility or registry editor to hide drives. To work with windows XP TweakUI go to Run command and type tweakui after that press enter. A small TweakUI interface will open with options to uncheck drives that you want hide. Click OK button to finish it.</span><span> And y</span><span>ou can also use registry editor to edit the computer registry to turn off the display of drives, but always be careful to when you work with computer registry.</span><br /> <p><span>The Follow given steps will help you to hide computer drives:</span><br /> <p><br /> <ul> <li><span>Here you will appear a small window locate the location to:</span></li> </ul> <p><span> HKey_Current_User \ Software \ Microsoft \ Windows \ Current Version \ Policies \ Explorer </span><br /> <ul> <li><span>Here right click on right side of the Registry editor panel and add new DWORD then put its value 3FFFFFF.</span></li> <li><span>Then close the registry editor and restart your computer after any changes to go into effect.</span></li> </ul>
on Dec 24, 2010 | Computers & Internet
What is the best method to hide a file in flash drive without any software?
The easiest method is change file to a hidden file.
Right click on the file - properties - tick on hidden
There is an advanced method, change file to a hidden file and as well as system file using MS-Dos.
I refer you to SmartUSB.net. It is a good source for flash drive users.
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 24, 2012 | Computers & Internet
File and folder names are not visible in one drive of my pc
For Windows XP:
Open the problematic folder, Press and hold SHIFT key, right-click in empty area and select "View -> Thumbnails". It'll toggle the file/folder names.
Actually its a feature to show/hide file names while in Thumbnails mode.
For Windows Vista and 7:
Open the problematic folder, right-click in empty area and de-select "View -> Hide File names". If the option is not available, then press and hold SHIFT key, right-click in empty area and select "View -> Medium Icons".
Jan 28, 2012 | Computers & Internet
Tip
How To Show Hidden Files And Folders In Windows 7 1. Open My Computer 2. Click...
1. Open My Computer
2. Click on the Organize tab
3. Click on Folder and search options
4. Click on the View tab
5. Remove the checks from "Hide empty drives in the Computer folder", "Hide Extenstions For Known File Types" and "Hide Protected Operating System Files" if checked.
Note you may have to scroll down to until you see both options. Also you may get the below pop up. You just need to click on the "Yes"
6. Click Apply and OK
Other Helpful Links
How To Show Hidden Files And Folders In Windows XP
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Aug 28, 2010 | Computers & Internet
Tip
Hide drives in your computer
we all know how to hide the folders, using windows hiding feature or using some softwares..
but, we can also hide the entire drive.. others cant know that there is such a drive..
Follow the steps below to hide a drive..
Please be careful in performing these steps:
Click on start
click on Run
Type in " gpedit.msc " (group policy), without quotes
Click on Administrative templates under user Configuration in the left pane
Click on Windows Components
Click on Windows Explorer
you will see the list on the right side..
Select " Hide these specified drives in my computer"
Double click it
select enabled
select the drive which u want to hide
click on Apply and OK
now refresh or close and open the my computer, the drive will be hidden..
Hope this will be usefull..
on Jul 24, 2010 | Computers & Internet
What can i do if one of my hard drives is lock
I had the same problem once, I bought an External Hard drive component...hook it up and the hard drive worked again....sometimes its the mother board...
Mar 27, 2010 | E-Machines eMachines Desktop PC
I receive an NTLDR error at boot up.
dude just copy the ntldr on other pc or windows....slave ur master drive on other pc that has windows then on other pc click my computer then tools then folder option then view then click show hidden files then uncheck hide protecting operating system...then back to my computer drive C: then all hide files will be seen then copy the NTLDR there into your harddisk put it in Drive C:
Sep 01, 2008 | Computers & Internet
Tip
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run...
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run > type “diskpart”.
a dos window will appear with following like that
DISKPART> 2. Then type “list volume” without quote
It will look like this.
Volume### Ltr Label Fs Type Size Status Info
Volume 0 F CD-ROM
Volume 1 C NTFS Partition 7000MB Healthy
Volume 2 D soft NTFS Partition 8000MB Healthy
Volume 3 E —- NTFS Partition 8000MB Healthy
3. If u want to hide drive E then type “select volume 3′ without quote
then a message will appear in same winwods { Volume 3 is the selected volume}
4.now type ” remove letter E” without quote
now a message will come { Diskpart Removed the Drive letter }
sometime it requires the reboot the computer .
Diskpart will remove the letter .Windows XP is not having capabilty to identify the unkown volume.
Don’t afraid ur Data will ramin same .
to Come back the Drive repeat the process . but in 4th step which is shown in this post replace ” remove” to “assign
means type ” assign letter E” without quote
The above method won’t work for the drive containing Operating System and it can also be done using System Manager>Storage Manager
on Jan 26, 2010 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
221 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
