Question about Proscan PS36600 36" TV
Proscan ps52810 52 inch projection - composite/HD problem
Hi, I have a background in Electronics Engineering, but ** schematics or service manual so I defer to the experts! My TV has been working well for 7 years. It has had quite a bit of use. The other day, I started hearing a buzzing sound in the speakers (maybe somewhere between 60 - 120 hz). After this I **ticed a faint red line sweeping up the screen. Now the top of the picture distorts when white/light colors appear and occasionally picture goes black (you can hear a relay clicking - maybe it lost sync?). I am running HD through the 3 composite video inputs (Y, Pb ...).
The strange thing is that it works fine using the coax input (set to channel 3). Of course I can't run HD that way. Is there a composite input board that can be replaced? Maybe there is a local oscillator that has degraded?
Any help from you Gurus would be grealty appreciated! I am **t in the position to buy a new tv and I will miss my HD!!!
Thanks!
Namaste
I want to know where is the fuses because I can't start my t.v. manual or with the control I open the back and front can see no image no contact nothing what can I do?
Posted on Jul 12, 2008
Wx416is. Where can I get a schematic diagram and instructions?
Search Results
    TV : Service Manual free download,schematics,datasheets ...
    www.eserviceinfo.com > Electronics > Consumer electronics > TV
    Electronics service manual exchange : schematics,datasheets,diagrams,repairs ...TV - Conventional CRT, LCD Projectors, TFT, Plasma, Big Screen, HDTV, ...
    TV LG : Service Manual free download,schematics ...
    TV - Conventional CRT, LCD Projectors, TFT, Plasma, Big Screen, HDTV, Home theater - Service .... dmLG_TIVICT29Q10ET_.gif · Service manual, schematic diagram and parts list ... Lafinion 82W.part1.rar · would like to get a service manual images for (CRT) Tv Where can I get a schematic
Dec 21, 2015 | Televison & Video
I have a samsung projection tv that turns off after it is on for a few minutes. It is a 48 inch HD tv. Is it the lamp or timer some sort of timer that turns it off automatically? Ray
Lamp Call Mats Electronics 1-800-628-1118 they have them for $99.00
Encompass Parts Distrubtion List all Parts /Prices with free Service manual you can print out
1-800-638-3328 their Lamp is $150.00
Mar 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Rca 52in rca hdtv
Hello lindseyskirk,
This is a common problem with this TV set as it uses the ITC222 chassis. The problem is usually localized to a group of capacitors
CP120, CP140, and CP150. If you have a background in electronics I can send you the schematics and you can unsolder them and replace them using the schematic to get the values from. If you do not have a background in electronics, I would suggest you have a qualified Television Technician do the replacement for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv will power on and off 3times but never completely power on
Hello All,
This problem is quite common in these type set which employ the use of the Thompson ITC222 chassis.
There are three capacitors that create this situation, they are:
CP120, CP140, and CP150. If you have a background in electronics and know how to solder well, this is an easy problem to take care of. This just requires the replacing of these capacitors.
So if you do have a background in electronics I have the schematic if you need it.
If you do not have a background in electronics I would suggest that you have qualified TV technician do this for you.
Thank you,
Shuttle83,
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Career in robotics
At my university, they offer a graduate program in robotic engineering. Here are the course requirements:
RBE 1001. Introduction to Robotics (Formerly ES 2201).
Cat. I
Multidisciplinary introduction to robotics, involving concepts from the fields of electrical engineering, mechanical engineering and computer science. Topics
covered include sensor performance and integration, electric and pneumatic actuators, power transmission, materials and static force analysis, controls and programmable embedded computer systems, system integration and robotic applications. Laboratory sessions consist of hands-on exercises and team projects where students design and build mobile robots. Undergraduate credit may not be earned for both this course and for ES 2201.
Recommended background: mechanics (PH 1110/PH 1111).
Suggested background: electricity and magnetism (PH 1120/PH 1121), may be taken concurrently.
RBE 2001. Unified Robotics I.
Cat. I
First of a four-course sequence introducing foundational theory and practice of robotics engineering from the fields of computer science, electrical engineering and mechanical engineering. The focus of this course is the effective conversion of electrical power to mechanical power, and power transmission for purposes of locomotion, and of payload manipulation and delivery. Concepts of energy, power and kinematics will be applied. Concepts from statics such as force, moments and friction will be applied to determine power system requirements and structural requirements. Simple dynamics relating to inertia and the equations of motion of rigid bodies will be considered. Power control and modulation methods will be introduced through software control of existing embedded processors and power electronics. The necessary programming concepts and interaction with simulators and Integrated Development Environments will be introduced. Laboratory sessions consist of hands-on exercises and team projects where students design and build robots and related sub-systems.
Recommended background: ES 2201/RBE 1001, ES 2501 (can be taken concurrently), ECE 2022.
RBE 2002. Unified Robotics II.
Cat. I
Second of a four-course sequence introducing foundational theory and practice of robotics engineering from the fields of computer science, electrical engineering and mechanical engineering. The focus of this course is interaction with the environment through sensors, feedback and decision processes. Concepts of stress and strain as related to sensing of force, and principles of operation and interface methods for electronic transducers of strain, light, proximity and angle will be presented. Basic feedback mechanisms for mechanical systems will be implemented via electronic circuits and software mechanisms. The necessary software concepts will be introduced for modular design and implementation of decision algorithms and finite state machines. Laboratory sessions consist of hands-on exercises and team projects where students design and build robots and related sub-systems.
Recommended background: RBE 2001, CS 1101 or CS 1102
RBE 3001. Unified Robotics III.
Cat. I
Third of a four-course sequence introducing foundational theory and practice of robotics engineering from the fields of computer science, electrical engineering and mechanical engineering. The focus of this course is actuator design, embedded computing and complex response processes. Concepts of dynamic response as relates to vibration and motion planning will be presented. The principles of operation and interface methods various actuators will be discussed, including pneumatic, magnetic, piezoelectric, linear, stepper, etc. Complex feedback mechanisms will be implemented using software executing in an embedded system. The necessary concepts for real-time processor programming, re-entrant code and interrupt signaling will be introduced. Laboratory sessions will culminate in the construction of a multi-module robotic system that exemplifies methods introduced during this course.
Recommended background: RBE 2002, ECE 2801, CS 2223, MA 2051
This course will be offered starting in 2008-09.
RBE 3002. Unified Robotics IV.
Cat. I
Fourth of a four-course sequence introducing foundational theory and practice of robotics engineering from the fields of computer science, electrical engineering and mechanical engineering. The focus of this course is navigation, position estimation and communications. Concepts of dead reckoning, landmark updates, inertial sensors, vision and radio location will be explored. Control systems as applied to navigation will be presented. Communication, remote control and remote sensing for mobile robots and tele-robotic systems will be introduced. Wireless communications including wireless networks and typical local and wide area networking protocols will be discussed. Considerations will be discussed regarding operation in difficult environments such as underwater, aerospace, hazardous, etc. Laboratory sessions will be directed towards the solution of an open-ended problem over the course of the entire term.
Recommended background: RBE 3001.
Suggested background: ES 3011
RBE/ME 4322. Modeling and Analysis of Mechatronic Systems.
Cat. I
This course introduces students to the modeling and analysis of mechatronic systems. Creation of dynamic models and analysis of model response using the bond graph modeling language are emphasized. Lecture topics include energy storage and dissipation elements, transducers, transformers, formulation of equations for dynamic systems, time response of linear systems, and system control through open and closed feedback loops. Computers are used extensively for system modeling, analysis, and control. Hands-on projects will include the reverse engineering and modeling of various physical systems. Physical models may sometimes also be built and tested.
Recommended background: mathematics (MA 2051, MA 2071), fluids (ES 3004), thermodynamics (ES 3001), mechanics (ES 2501, ES 2503)
RBE/ME 4815. Industrial Robotics.
Cat. I
This course introduces students to robotics within manufacturing systems. Topics include: classification of robots, robot kinematics, motion generation and transmission, end effectors, motion accuracy, sensors, robot control and automation. This course is a combination of lecture, laboratory and project work, and utilizes industrial robots. Through the laboratory work, students will become familiar with robotic programming (using a robotic programming language VAL II) and the robotic teaching mode. The experimental component of the laboratory exercise measures the motion and positioning capabilities of robots as a function of several robotic variables and levels, and it includes the use of experimental design techniques and analysis of variance.
Recommended background: manufacturing (ME 1800), kinematics (ME 3310), control (ES 3011), and computer programming.
Dec 16, 2008 | Microsoft Windows Vista Ultimate Edition
Screen goes black and resets during HD shows
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Aug 31, 2008 | Sony KP-53HS10 TV
Hi there, you seem helpful, I have a Proscan PS61670 rear projection TV, I believe i need to replace the IC however in my service schematic it shows the "Digital Convergence IC" on the board as a STV2040T,...
Thats an obselete IC. Your model came with two chassis designs the CTC195 and the PTK195 could you verify which chassis your model has and I will try to cross refernce it to a substitute part number for you. Please respond to this same post when replying.
Jul 27, 2008 | Proscan PS61670 61" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
