Question about Apple MacBook Pro PC Notebook
Apple macbook pro
I have an apple macbook pro and the system wont boot after my kids got a grip on it. when i power it up all i get is a flashing apple the international stop sign which flashes back and forth between the two. it just flashes back and forth back and forth. Has anyone send this before??/ help
  • risaun721 Mar 11, 2008
    its a constant back and forth it wont sop unless i power it down.
    Scholar:
  • 163 Answers
Http://forums.macrumors.com/forumdisplay.php?f=129 Look here first as I'd need more info prior to Guestimating the cause.. (Were Swamped).. Any way post back.. Sounds like drive failure to me or similar/OS Issue but could be more. Is the flashing/Change Timed or an Intermittent thing..
Posted on Mar 11, 2008
  • Ken LaDere Mar 17, 2008
    Most likely hard drive or MAC OSX corruption.. (I'd try hard drive)....These new Intels are a whole diff. Ballgame as opposed to the older Ibook's and failures..
Unlock MacBook pro
On the newer macs, you can hold down D while booting which will take you to diagnostics mode. There you can reset the password. For older systems, you will need boot media.
Feb 11, 2015 | Apple Computers & Internet
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
Macbook a1278 flashing ?
Put your OSX disc in, if that loads then you need to have your hard drive looked at, the operating system may also need to be reinstalled. But first, have a tech look at it.
Dec 12, 2013 | Apple MacBook Pro Laptop Computer with...
When I turn my apple MacBook Pro on it goes to a system lock pin entry screen. I tried resetting the ram but then it goes to an administration password entry screen. What options do I have. I think the...
If you have a apple store account and wifi, you hold down the Option and the R buttons while booting until the apple symbol appears, follow menu from there to install proper OS
Sep 21, 2013 | Apple Genuine 13.3" Macbook Pro Unibody...
Macbook pro usb short circuit
Take the phone, computer, and cable to the Genius Bar in your closest Apple Store and ask them to look at it. This is hard to diagnose through text; they will be much better equipped to help you.
Jun 09, 2013 | Apple MacBook Pro Notebook
My screen is white & wont allow me to login?
my advice,
use a macbook laptop recovery disc to recovery your system, you may have corrupted the boot file system.
May 24, 2010 | Apple MacBook Pro Laptop Computer with...
Start problem
Hi, Sorry to hear you are having problems,
You are describing something quite strange, normally, you get one of those 3 images.
The circle with a slash through it indicates that your system cannot boot that model Mac.
The folder with the ? flashing indicates that a Boot drive cannot be found.
And the Apple Icon indicates that the system is now Booting.
So, your MacBook Pro is suffering from multiple personality disorder.
You would do best to re-install the system right over your old system using the ( Archive and Install ) Option making sure you keep your existing users.
Also, be sure to run Disk Utilities before installing the System, run Repair Disk and Repair Permissions on your internal drive a few times until there are no more problems found, then install.
Once you have done this, your Mac should boot up properly. You will then need to run Software update a few times until there are no more updates.
Sounds intimidating, but don't fret, it's one step at a time..
Apr 02, 2009 | Apple MacBook Pro Notebook
Audio driver for Macbook pro
The drivers for XP are on the official OS X Leopard DVD. Install this when running XP and then run the Apple Drivers Set up on the disk.
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
Apple MacBook Pro PC Notebook Logo
152 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
