Sometimes when I leave my comp on and it the screen goes black I'll wiggle the mouse and my monitor says "** signal rgb" I have to turn my computer off to get the picture back. How could i fix it without having to unplug my computer every time?
    Master:
  • 351 Answers
Dear Carthorne,
just go to the Control penal then click on Power options, then choose the monitor power and select the *****.
maybe there is time alloted to monitor so you have to select it *****.
Cheerup and Be Happy Always
Posted on Mar 10, 2008
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Gateway lcd monitor goes off and on!
First, check to make sure the input selection switch isn't stuck, after unplugging the monitor power cable. It sometimes can get stuck, or just become damaged.
If this isn't it, maybe it's time for a new monitor.
Feb 14, 2012 | Gateway FPD1975W 19" LCD Monitor
How do I turn Off the RGB no signal screensaver on my VIZIO ? Everytime I get comfortable on the couch it goes blue screen on me and makes me get up to move the PC's mouse.
the problem is on the pc my friend not the tv, right click on the desktop of the pc and click properties or screen resolution then click on screensaver .then change the turn monitor after 30 minutes or whatever its set to , to none. Then your tv wont show no signal as the pc wont be turning off the signal
Mar 30, 2011 | Vizio GV42L 42 in. LCD Television
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
Hp 2009m screen goes black - no signal
change frequency setting to 60hz from the option of graphic setting using another monitor then agin connect your problematic monitor.
step1.open properties on desktop using right mouse click.
step 2.goto last tab (setting)
step3.goto advance optinion
step 4.goto third tab(monitor)
and there is option of frequency change it to 60hz save it and press enter.
now shutdown computer then connect your screen goes monitor check it.hope it works.
when screen black its mean the range of signal frequency higher then compatible frequency.
Aug 01, 2009 | Computers & Internet
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Cheers.
Z
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
Connecting PC to TV
sorry guys sound is not ment to be transmited through a rgb cable its just for higher quality video you can use a the red and white RCA inputs to get sound to your tv but you need a headphone jack -rca cable or if you tv has a headphone jack just buy a cable with one headphone jack on both ends
hope this helps
May 17, 2008 | LG 32LC7D Television
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
