Question about GE Spectra JBP78 Electric Kitchen Range
Ge range jb970 oven control reading 2 2 fan symble 2?
My oven controls are reading 2 2 fan symble 2
the dr
  • 447 Answers
SOURCE: GE JSP69 Electric Kitchen Range Controller Problem
Yes replace the EOC (electronic oven control) after you verify that the board is getting power (no burned wires, no loose connectors) there usually is not a loose wire and the clock has failed. www3.sears.com for parts i can help with parts lookup and sourcing if needed will need complete model #
Posted on Oct 07, 2007
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Posted on Jul 22, 2009
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
Jul 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When oven is turned on, display immediately indicates that the oven has reached set tempurature and fan turns on. Fan remains running for about twenty minutes after oven is turned off. Note oven has not...
bad oven sensor or control board.oven sensor should read ~1100 ohms when cold if not replace sensor .if sensor reads good you have a bad control board.some sensors can be tested from inside oven other have to go thru back. Hope this helps please rate my solution :)
Jun 25, 2009 | GE Cafe CGS980S Kitchen Range
Panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
F1 fault
Here are the fault code for GE:
GE
Code
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
90 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
