Question about Pullman Holt Vacuums
Cleaner won't dispence cleaning solution
Hi, we have a pullman powerwash v-024, and it won't dispence the cleaning solution. The tank is in correctly but we don't get any spray of water when we press the trigger button. We are in Australia and i don't know if you even know the product but hopefully u might be able to help us. Thank you
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Posted on Jun 29, 2010
Pullman vacuum model AS5 user manual
Hi There, The Pullman AS5 is exactly the same machine as a Cleanstar Hypervac AS5. If you email us on the VacuumSpot contact us page I can forward it to you.
May 25, 2013 | Vacuums
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Powerwash Deluxe will not dispence the water, i have cleaned all the pipes and checked the belts, all fine, any other ideas!!!
this video is a good place to start , if thid does'nt work you need to check the heater tank for blockages
Jan 01, 2013 | Vacuums
Bissell powerwash upright deep cleaner 1690 j
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
werw
Jul 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
dispense
Possible cause
Possible solution
Possible cause
Possible solution
shut off engaged
correctly
cleaning
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
WE HAVE JUST GOT A POWERWASH 1690J GREEN/GREY SECOND HAND AND NEED INSTRUCTIONS AND INFOR FOR CLEANING LIQUIDS FOR IT PLEASE
if you follow this link it will take you to the insructions you want i had the same problem and have just down loaded the insructions for a powerwash 1690j http://homeappliance.manualsonline.com/manuals/mfg/bissell/1690_1695.html
Jun 03, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I require instructions on how to use the Bissell Powerwash
Contact the Bissell services in your country - most of the Bissell sites (www.bissell.com) for example have Adobe user instructions of which you can download.
Apr 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I'm using way more cleaning fluid
i am bisell dealer and i would reccomend mixing soap in the clean water tank and place just water in soap tank to get more accurate dispencing because there is no other adjustments on the unit
Mar 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
384 people viewed this question
Top Pullman Holt Vacuums Experts
Marvin
Marvin
Are you a Pullman Holt Vacuum Expert? Answer questions, earn points and help others
