EventViewer Error Plz giv tips for - """The device, \Device\Ide\IdePort0, did not respond within the timeout period"". for solve that error on Event viewer on my desktops
    Novelist:
  • 104 Answers
Every time you get messages talking about "TIME PERIOD" you have problems with transference... this can be caused by:
Cables Damaged
Units or Drives Damaged
RAM damaged failing
Discs or info damaged
Power failures in or out the units
software (operative system) damaged
not so common, virus activity
Just to make an example: if you are trying to get information from a CD to the HD and that happens... probably the Compact Disc is damaged or the CD Reader or the HD is.
Good Luck and try to specify all you can when you have problems... otherwise it is very hard to help. Computers are almost like human body, anything could happen to them, even the rarest and stupidest thing can drive your systems crazy...
Posted on Mar 10, 2008
Sony kv 29ls35e error codes
To enter into service mode to these sets,
* Turn on the Tv with its main ON/OFF switch at its front panel. [Standby Mode].
** Press the following buttons on the remote control in sequence. [ON SCREEN DISPLAY => DIGIT-5 => VOLUME --ve => TV].
The identification of errors within the [FE-2] chasis is triggered in one of two ways. [1] Busy. [2] Device failure to respond to IIC. In the event of one of these situation arises, the software will first try to release if the bus is busy, and then communicate with each devices in turn to establish if a device is faulty. If a device is not to be found faulty, the revalent device number will be displayed, with series of flashes of LED, which must be counted. Each time the software detects an error it is stored within the NVM.
No error => 00
Reserved => 01
OCP [Over Current Protection] => 02
Not used => 03
No vertical Sync => 04
IKR Error at power ON => 05
IIC bus clock and /data lines low at power ON => 06
NVM no IIC bus acknowledge at power ON => 07
Not used => 08
Tuner no acknowledge at power ON => 09
Sound processor error => 10
Jungle controler 8V error => 11.
Jul 22, 2014 | Computers & Internet
Keyboard on laptop A52 joybook somtime not working
your product is overheating, because of the cooler fan cant push air in the cooler cells, your computer is overheated because its jammed with dust and should be cleaned out of a tech-man
Jan 21, 2014 | BenQ T2370 Notebook
Error i/o device error (0x8007045d)
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Two of the most common causes of I/O (Input / Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motor like force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; Otherwise, Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware. Hope this helps.
Jan 03, 2013 | E-Machines eMachines Desktop PC
Inspiron 8500 laptop (80GB) intermittant boot failure
Hi
Thank you for your query
If there is a clicking noise inside then the hard drive is on the way out, the arm that reads the data is knocking against the plates, thus the noise
I would recommned that you back your data as soon as possible as the drive will eventually fail
Please can i ask that you leave feedback and vote if this has been useful
Feb 12, 2010 | Dell Hard Drive for Inspiron 8500 and 8600...
I get error rtl100.bpl what must i do
hi
i am techbuddies from fixya group i would like to try and solve your issue .
please try to follow these steps
You probably read web pages written in a language that displays Right To Left
(hence rtl100) There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
if is doesnot work then try this
Are any devices malfunctioning? Select Start, All Programs, Accessories,
System Tools, System Information. Open Components under System Summary
and click on Problem Devices. Is anything listed there?
Are there any yellow question marks in Device Manager? Right click on
the My Computer icon on your Desktop and select Properties,
Hardware,Device Manager. If yes what is the Device Error code?
Does anything turn up in the Event Viewer Logs?
You can access Event Viewer by selecting Start, Control Panel,
Administrative Tools, and Event Viewer. When researching the meaning
of the error, information regarding Event ID, Source and Description
are important.
A tip for posting copies of Error Reports! Run Event Viewer and double
click on the error you want to copy. In the window, which appears is a
button resembling two pages. Click the button and close Event
Viewer.Now start your message (email) and do a paste into the body of
the message. Make sure this is the first paste after exiting from
Event Viewer.
if the same problem comes up please try to get in touch with me on my email or on fixya
thanks
techbuddies
Dec 30, 2009 | Dell Microsoft Windows XP Home Edition
I have a poweredge 4200 which has a pedge error in the event viewer - device scsi port 2 did not respond with in the timeout limit - is this a harddrive failure? There doesn't seem to be any errors showing...
If you're getting this error message very frequently then change the hard drive connector to any different available SCSI port on the motherboard. This issue is generally caused due to a problem in the SCSI port on the mobo.
To stop the Beep alert, click Start button, Control Panel, Sound devices.
In the sound properties window, click on the Sound tab, then select and highlight the "Default Beep" under the Program Events section then select "NONE" from the drop down under the Sounds section then click Apply and OK.
Then, restart the Computer for the changes to take effect.
Nov 09, 2009 | Dell PowerEdge 4200...
Acer Aspire 9500 Temporaily hangs and won't boot
hi, the controller you speak of is indeed emmbeded on the board.
you might try removing your hdd and reseating , try the same with your ram and cd/dvd drive i have had this on a travelmate 2410 turned out to be the dvd drive needed reseating.
hope this helps
Feb 21, 2009 | Acer Aspire 9500 Notebook
Hard Drive Freezing PC
Back up your hard drive asap, it it's starting to fail. Purchase a SSD type hard drive as a replacement. Good luck.
Nov 24, 2017 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
