Intellisync (607957652421) for PC Logo
Anonymous Posted on Mar 17, 2010
I just purchased a Palm TX and have installed Palm Desktop 6. I also have installed Intellisync and have configured it so that datebook is linked to Lotus Organizer 6.0. Although the hot sync report states that datedbook and other files have transferred successfully, when I go to Calander on the Palm TX, the only thing on the page is today's date and nothing else except the options view bar. However, everything on the Palm TX is locked. The only way I can get it unlocked is to perform a soft reset, but this does not solve theproblem with Calendar. Please tell what is causing this and how to fix it. Thank you!
  • 2 more comments
  • Anonymous Mar 18, 2010
    Thank you for clearling up my problem using Intellisync and Lotus Organizer 6.0. I removed Intellisync from my computer. I went to the LapLink site and downloaded PDAsync 4 since it claims to be able to synchronize with Lotus Organizer 6. I did a hard reset on my Palm TX although afterwards, my Contacts information was still there. I tried to set up PDAsync 4 so that Lotus Organizer 6.0 would be the source of my Calendar and Datebook entiries. I got the following error message: "Default Organizer file not found. Use Organizer to create at least one file and try again." I'm not sure what this means since the setup of PDAsync4 appeared to have the right data file for Organizer. When I did a full synschornization, the report indicated that it transferred the Calendar files, I went to "Calendar" and there was nothing there but the same screen just showing the date and view options. Again the whole PDA TX was locked. Doing a soft reset did not correct the problem. Please advise as to how to solve and/or get around this problem as without the Calendar function, the Palm TX is useless to me. Other than Calendar, the other Palm TX functions seem to be working. Please help. Thank you!
    The security features are not even turned on. Calendar is the only application where data is not transferred. In PDAsync 4, there does not appear to be any place where a choice is made between Palm Desktrop and the sync program. If I do a hard reset and no sync following it., the Calendar application appears to work properly even though there is no data in it. I would really appreciate it if you could identify the source and nature of this conflict which is preventing the transfer of this information and the crashing of the Palm after the sync. Please advise a.s.a.p. Thanks
    What is the backup folder called? Please advise a.s.a.p. Thanks!
  • Anonymous Mar 20, 2010
    Where do I find the backup folder and what is its name? I also installed PDAsync 4 since it is supposed to work with Lotus Organizer 6.0. I am trying to set it up to have Organizer as the conduit for Calendar, but I get the following eror message: Default Organizer file not found. Use Organizer to create at least one file and try again." What type of file are they talking about? Also, when I press the "Synchronize" button in PDAsunc, I get the following error message: "Unable to find HotSync. Please restart HotSync. If this doesn;t work, please reinstall HotSync and try again." I don't know why I get this message since I assumed HotSync was always on. Please respond a.s.a.p. Thank you.
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Mar 21, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4005399
Points
36390
Open Palm desktop, menu Tools-> Options, the General tab shows you and lets you change where the data files are.
There are really only three main places user files go in Vista:
  • \Program Files\program-name\
  • \ProgramData\program-name\
  • \Users\user-name\somewhere-in-there\
    • Usually one of these:
      • \Users\user-name\AppData\Local\program-name\
      • \Users\user-name\AppData\Roaming\program-name\
      • \Users\user-name\Documents\
Mandeep Singh
Level 3:
  • Master 1,184 Answers
  • Posted on Mar 19, 2010
Mandeep  Singh
Master
Level 3:
Answers
1184
Questions
11
Helped
474531
Points
3414
Intellisync sometimes tends to give problem with the Palm and the pc sync . You can try an alternative for the same like Easysync from Lotus itself.
You can read through the following links for more info
http://kb.palm.com/wps/portal/kb/common/article/7855_en.html
http://www.versiontracker.com/dyn/moreinfo/win/34614
Thanks for using Fixya
Proton
Bhautesh Patel
Level 3:
Guru:
  • Master 402 Answers
  • Posted on Mar 18, 2010
Bhautesh Patel
Master
Level 3:
Guru:
Answers
402
Questions
0
Helped
126648
Points
1181
How did you move from Zire to TX ? Simply plug-in and sync?
Try this:
- hard reset TX
- locate backup folder under palm desktop folder tree
- rename to backup_old
- sync, select old id. This will bring back PIMs (Calendar, Contacts, Tasks and Memos) but no settings nor programs
- reinstall applications one by one AFTER making sure they are compatible with the target device.
And Thanks.
Anonymous
Level 3:
  • Master 532 Answers
  • Posted on Mar 17, 2010
Anonymous
Master
Level 3:
Answers
532
Questions
0
Helped
172085
Points
1592
Unfortunately, the answer is that this device is not compatible with Hotsync versions newer than 4.1 and the Palm requires a newer version.
Here is the complete answer from IBM.
Lotus Organizer only synchronizes with Palm handheld units using HotSync version 4.1.
The Palm Tungsten T5, Palm Tungsten E3, Palm TX, and the Treo 650 ship with a new version of HotSync version 6.01. This newer version of HotSync is not compatible with EasySync for Organizer. In addition, the Treo 700 series phone uses the Windows Mobile 5 operating system which is not supported.
NOTE: These handhelds cannot be synchronized with a version of HotSync Manager prior to 6.0, due to their new NVFS flash memory architecture. This is different from previous Palm PDAs which used conventional volatile RAM and HotSync Manager 4.0.
Some customers report success using Intellisync Handheld Edition from www.pumatech.com. Other customers also report good results using Laplink's PDAMover at www.laplink.com.
    The information regarding "Palm TX is locked" indicates that the security features are enabled. If this is the case, try disabling those.
    The information regarding the information still being on the Palm after the reset indicates that the Palm did not actually reset completely. This may prevent any "clean" syncing.
    Pardon my question here, but, do you have the conduit set to have the Lotus Organizer to overwrite the Palm?
    I will continue to investigate other options so, let me know if you make any progress with the things mentioned here.
    Palm uses Hotsync to make transfers.
    Go to the Palm.com site and download it. It looks like a circle in blue/red.
    This is where the conduit settings are.
    The organizer file is created when a calender or other item is created on the Palm.
    Make a test entry and retry the sync after you have installed the Hotsync software. Hotsync is not the same as Intellisync.
    I hope this helps you.
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
10helpful
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Purchased a used Palmlllxe and need the start up cd and owners manual
Here you go.
http://kb.palm.com/wps/portal/kb/common/article/47831_en.html#palm3xe
This has links to manuals and software. To get started you need the Palm Desktop, which allows you to backup and restore most of your data. This also provides the Hotsync Manager utility, whcih you can use for installing applications and syncing.
for baba here is the link for Tx
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
M515, re installing basic software
Hy floody, this may sound like something you already checked, but you will notice in the top right corner of palm desktop there is an drop down arrow, is it set to System? If so , set it to all. Let me know how you go.
Brand new Palm TX wont let me set the date to this year
Are you both sure that under the World Clock icon that the current date/time is set to the right year?
Sometimes the dates get set back incorrectly if the Palm dies.
Intellisync problem
First, uninstall all software, Palm Desktop and Intellisync. Move the user files to the desktop. Reinstall all software. Try a sync. If this doesn't work, move the user files back to the proper location. Then uninstall all software, Palm Desktop and Intellisync. Now do a hard reset of palm unit. Try sync-ing.
Top Intellisync Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Intellisync Computer and Internet Expert? Answer questions, earn points and help others
