Question about Uniden Cordless Phone
GE dect 6.0 28300 'net in use'
When i try to skype from my phone, it seems to work for 1 skype-out and then it will say 'net in use' if i try to use skype again after that. I can fix it by signing out resetting and signing back in! any suggestions? thanks
  • 2 more comments
  • mrssteve Nov 11, 2008
    Mine in a Dual kype phone I am currently on version 3.8.0.180which since installing shows "NET IN USE" when I click the green button to make a call or when I try to answer a call
    Steve
  • twidave Nov 15, 2008
    After every call I have to sign out and sign back in because the handset says "Net in Use". This is a pain in the **** because my computer is in another room. I also can't dial directly from the phone anymore - only through the computer. However, once a number is in the "Skype outgoing calls" list on the handset, then I can select it and dial... as long as I don't get the "Net in Use" problem. :(
  • twidave May 11, 2010
    Steve,
    You are saying that you just unplugged the phone's (cradle's) power supply and then plugged it back in and you haven't had the problem anymore?
    Thanks,
    ./dave/
    Tim,
    Thanks so much for that quick response about the country code - I remember seeing it a long time ago, but forgot. :(
    Now if we can only clear up the "Net in Use" and how the heck you can play your voicemail through the handset, this would be a great phone!
    Thanks again for your help. :)
    ./dave/
I found the answer - I have two Skype DUal phones - I just disconnected from the mains power supply and then reconnected - FIXED - Enjoy
Steve
Posted on Nov 15, 2008
I had the same problem when trying to dial a number without going through my contacts. Here is the solution that worked for me:
To dial a number you must enter "001" first, then the area code, then the rest of the phone number.
Format: 001,area code,phone number. You must do this even if it is a local call. This is in the manual for this phone on page 28. The manual is located at this link:
http://www.home-electronics.net/ge/pc/IB/French_Canadian/28300EE2_IB.pdf
Hope this helps,
Tim
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Posted on Mar 27, 2010
Testimonial: "thank you very mucy "
Why is keypad not functioning on GE 31591
Usually the connector socket comes loose. Open it up and check it is OK. Failing that give it a clean under the keys with soft cloth or pencil eraser.
Aug 26, 2014 | GE 31591Cordless Skype Phone w/ DECT 6.0...
Need an instruction mnual for GE 28112EE3-A Dect 6.0
Thomson built the 28112 Expandable DECT 6.0 phone for GE. They have the manual available on their support site: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
I hope this helps.
Jan 10, 2012 | Lands Phones
Need instructions to reset time on our GE DECT 6.0 cordless phone
You know how MANY Dect 6.0 cordless phones G.E. makes?
Here is a link to GE, look for the model number on the bottom of the phone.
And search for it, or look at the pictures and click on the picture of your phone... then after that near the middle of the page slightly to the left there is a Bloue Box - Product Instruction Book - English... press this to get your manual.
http://www.home-electronics.net/ge/pc/showsearchresults.asp?pageStyle=H&resultCnt=10&keyword=dect+6
Good Luck!
Mar 26, 2009 | GE 29897GE1 Corded Phone
GE Cordless Dual-Line PC Phone for Skype will not find network
Have you uninstalled the driver/software and then reinstalled it?? Give that a shot!!
Mar 26, 2009 | RCA General Electric 28310EE1 Skype IP...
GE 6.0 Dect 28300 not working in Vista w/skypemate
Uninstall skypelink and remove the usb cable of the phone from the computer. Reinstall, and after install, plug in the usb cable.
As per installation instructions, you shouldn't plug in the USB before you have installed the software....
Mar 24, 2009 | GE 28300EE1
GE cordless phone 28300EE1-A driver
Here you go:
Click on the link below and then look for "Download Skylink 2-in-1 Phone Utility"
http://www.home-electronics.net/ge/pc/viewPrd.asp?idproduct=18
Dec 10, 2008 | RCA General Electric 28310EE1 Skype IP...
I have a GE 27909EE1 Dect 6.0 phone and cannot find the manual. I need instructions in order to program it.
Here's a link to the manual for the GE 27909EE1 Dect 6.0 phone on the manufacturer's website. You can download it free and print it if you wish.
http://www.home-electronics.net/ge/pc/IB/27909EE1_IB.pdf
Dec 02, 2008 | Lands Phones
Dialling from computer then taking call on phone?
Hi zappawo, This is impossible with the Philips VOIP321. A design flaw. You have to live with it or buy another one, like the GE/Thomson GE21878. I bought the GE with this question in mind. The GE does take over the calls from the screen to the handset. As it should be.
Best regards, Fred
fred.altmann@gmail.com
Oct 27, 2008 | Philips DECT VOIP-321 cordless telephone
Uniden Cordless Phone Logo
352 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
