Question about Samsung LE26R74BDX 26 in. HD-Ready LCD Television
Samsung lcd faults
I have a Samsung Le26r74 and it has locked on channel 3 with ** picture.i cant get any digital menu.
  • Gibbo855 Apr 06, 2008
    Exactly the same problem with mine, except I am on Channel 2!!! I was hoping that it would have some kind of reset facility available.
  • francismurto Aug 15, 2008
    Stuck on channel 3 with the blue channel bar at top. Can go into analogue, but if you return to DTV the picture is frozen from last view! Have tried the fix desribed, but my tv goes straight back to channel 3, it will not give me the special reset menu...any suggestions?
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Posted on Apr 06, 2008
Used info. mute etc buttons as described, got into service menu, found reset, but pushing enter/ok button did not work, you have to use scroll right button to complete reset, found after trying all scroll buttons, hope this helps others'
Posted on Dec 26, 2008
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
Our Samsung LE40B550A5 LCD TV keeps losing its stored digital channels (reverting back to ATV) when you are browsing through the channels or more commonly when you use the digital text function. It is an...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 24, 2017 | LG 15LC1RB 15 in. LCD Television
Cant access the digital menu since the digital change over. Still recieve analogue channels 1 to 5 samsung lcd tv model LE32N73BDX
Hello Gregor_69
Lets see if we can get you sorted out. Please follow my steps and you will be back up and running in no time.
with you samsung remote make sure you press the TV button so that we are on a TV channel and not one of the other inputs.
Then press MENU
down to CHANNEL
go to AUTO STORE
you should find two option on there 1. air 2. cable
You want to highlight the air and START.
it will now give you 3 option
Digital & Analgue
Digital
Analogue
highlight the Digital option and START.
This will auto tune just your Digital channels. Once this progress bar has finished. You should find that all your Digital channel have returned to normal.
I hope that this has helped you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 11, 2009 | Televison & Video
Digital ready TV locks up on channel 3 only
AUTO PROGRAMM YOUR CHANNELS AGAIN. IF THIS DOES NOT FIX IT THEN YOU NEED TO HAVE THE MAIN TOTAL ASSY REPLACED
Jun 22, 2009 | LG 32LG40 32 in. LCD HDTV
Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Dec 31, 2007 | Samsung LE40R74BDX 40 in. LCD Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Nov 20, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
1,516 people viewed this question
Jerry Greenberg
Jerry Greenberg
