Question about Canon PIXMA IP5200 InkJet Photo Printer
Canon IP5200 Printer
My Printer has just started printing in Blue/Black mix instead of Black.
I looked inside the unit, took out the cartriges, lifted the lever to the left hand side of the cartrige holder and lifted it out. The Blue one was a bit messy and the sponge running along the bottem track was wet and messsy. (Q) Does the printer need a new Head. (Q) How do I clean the sponge, is that a spare part. Can you help me please!
Regards Mike Redman
ginko
  • 19396 Answers
SOURCE: MP140 do not recognize cartrige
Ensure that you are using original cartridges.
Clean the cartridge sensor inside the printer ink carriage with isopropyl alcohol and cotton. From description it looks like a faulty cartridge contact.
The cartridge sensor is the metal plaque that connects to the cartridge chip, is located inside the printer carriage.
Posted on Nov 20, 2008
SOURCE: Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Posted on Dec 13, 2008
  • 240 Answers
SOURCE: Printer does not recognize a full ink cartrige. Problem has responded to removing and then replacing the cartrige in the past, but that no longer works.
try to unplug your printer while it is in ON state ...it reset all your settings and after that it can recognizes your full cartridges..
Posted on May 17, 2009
ioktay
  • 493 Answers
SOURCE: Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Posted on Mar 25, 2010
LaQueen
  • 20 Answers
SOURCE: how do i install refil cartriges without the
Hello. Reset your printer to reset ink.
Press and hold the STOP/RESUME button for at least 6 seconds. Just wait for the printer to initialize.
Posted on Jun 12, 2010
Canon MP640 won't use pgbk cartridge
its maybe air leak to cartrige.check the hole on cartridge must closed.then clean head by printer propertis .cleanhead for 4 or 5 times
Oct 04, 2017 | Canon MP640 All-In-One InkJet Printer
Why is my printer printing green instead of black when I press black button
i think you need to check your cartrige levels youll find either they are low or you mixed them up
Mar 06, 2014 | Canon Office Equipment & Supplies
My color print outs, like mapquest, look like cartoons instead of pictures. I did a noozle check and yellow isn't printing. I took the cartride out and touched a paper towel to it, and the ink came out....
Never use aftermarket cartridges with your Canon Pixma ip5200 inkjet photo printer.
If your cartridge leaks fluid when out, then that's not a good sign.
Try to return for a refund if you just got it.
Aug 19, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Printer prints blue instead of black
1) make sure that the ink cartrige is black
2) make sure that it is loaded into the correct slot
Mar 19, 2010 | Canon PIXMA MX310 All-In-One Printer
The ink cartriges wont fit into the printer.
This printer uses PG-30 and Cl-31 ink tanks. You can also use PG-40 and CL41. Open paper output tray. Turn on the machine and lift up the scanning unit or printer cover. Pull unit support down into place and the ink holder will move to the left. Gently remove cartridges and install new ones. Let me know of outcome.
Jun 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer does not print black & White documents
You just have to clean the printer head or change it.
Happend to me and solved it:
Open the top the way you use to change an ink cartrige...Unplug the power cord.. the ink tray will stay accessible.
Save your ink in some plastic wrap.
Just where you pull the ink cartriges is the head. Lift the little arm on right top of the assembly and pull toward you the black plastic kind of container..(for ink cartriges)..
that is where the head is attached. DO NOT FORCE anything..it should come easily.
At first place in warm clear water..use rubber gloves..often change water. When it looks quite clean..it is not. Unscrew the two littles screws holding the flat ribbon tip where the ink should go out..Beware...lift it gently..
underneat there is a small rubber part..just lift the end covering the black ink exit...Now pour all this in warm water mixed with Windex for some time and change the water till it comes quite clear. Now blow air from a compressed air can in the black ink canal..you will be surprise to see the amount of plugged ink coming out from there.Rince, dry with compressed air,screw back parts,place everything back and try an head alingment test to see your Black here again..
Apr 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
No cartrige
Dear malakes,
It means the cartridge is faulty and need replacement with new one. .
Aug 21, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printing B&W photos
www.fixyourownprinter.com maybe you can find something here in forum pages
Jul 15, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
21 people viewed this question
old marine
old marine
