Question about HP Pavilion dv6000z Notebook
My wireless assistant
Hi,um switching on my wireless assistant on my laptop and its not turning on.even if i click on the shortcut on my desktop nothing happens!help, mu only internet connection at work is wireless
  • Jamad May 11, 2010
    The bluetooth setting on my Hp pavilion dv6000 with AMD Turion processor ( Windows vista home premium) shows "Discoverability and Connectivity setting not properly saved" anytime i tried enabling it for detection.
    Hence i cannot see to any bluetooth device to connect to.
    Help me with this so that i can use my laptop to communicate and exchange files with the bluetooth on my phone.
  • 100 Answers
First check the Wireless button.Whether its ON or OFF.
Otherwise reinstall the drivers and check it.
Thanks
Posted on Mar 10, 2008
I have a problem with my compaq presario cq42, i am not find out my wireless option,even i was downloaded hp wireless assistance and others driver but nothing happen. Please give me some idea!!!!!
If you can download then I expect the wireless bit is working. Try re-booting with an Ethernet lead plugged in, download the latest drivers from Hp and clicking on the downloaded name will install the driver. Ensure you choose the correct driver!
Oct 22, 2013 | Lifetime Compaq Presario CQ42 Replacement...
I can't switch on wireless for my laptop.. i press fn/f2 but still nothing happen.. so, i wonder if my wireless button does not functioning anymore.. if it does happen so, what else can i do to switch...
In order to switch wireless on there is a Wireless assistant available in your Control panel like I am using a hp laptop so there's an HP wireless Assistant available in the control panel. Open it and there will be a WLAN option. Simply turn it on !!! Bingo !!!
Sep 24, 2010 | Acer Aspire One PC Notebook
We have an Advent 7088 laptop and want to connect it to wireless router. We thought a wireless facility was already installed in the 7088 but when we try the wireless on/off button nothing happens. What...
Try this: I found it after doing some searching on the web.
Wireless card stops working after upgrading to Windows Vista
After upgrading to Windows Vista everything works fine apart the Marvell Wireless card, when you press the button nothing happens.
There seems to be three different ways of solving this problem (there is a fourth - don't install Vista) and I've listed them below, hopefully at least one should work for you.
The first solution is to press the wireless button while Windows Vista is loading, you have to be quick though as it only works if you press the button between the loading scrolling lines logo (after the post screen) and before the windows logo appears.
The second is to go into Device Manager, select the Marvell Wireless card and then go to Properties>Advanced>Default Adhoc Mode. Here change the Default Adhoc mode to B or G. When you confirm the change the wireless connection should become active, if it doesn't then press the wireless button and try changing the setting again.
The third method is to create a desktop shortcut to the wireless adapter. Go to [Network and Sharing Centre]>[Manage Network Connections] and then right click the wirless connection and choose Create Shortcut. You can then switch on the wireless at any time, just point at the shortcut then right click and chose Disable. Once its disabled right click on the shortcut again and choose Enable. It should then connect within 20-30 seconds.
Support site: http://www.uktsupport.co.uk/advent/laptop/7088.htm
Mar 11, 2010 | Computers & Internet
How to turn off wireless on Advent 5421
You can disable the wireless adopter
Type ncpa.cpl in run command
It opens the network adopters in ur laptop.
Right click the wireless adopter and disable
Thanks
Siju
Aug 28, 2009 | Dell Inspiron 1525 Laptop
My laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
May 07, 2009 | Acer Aspire 5920 Notebook PC
Unable to save my word documents when I click on save
If it was truely a shortcut and was deleted, the data is still in the folder on the hardrive (c:) and can be accessed with the file manager or exploring the c: (root) drive. once you find it , right click on it , select "make shortcut, then drag the shortcut to your desktop.
If it was a folder (not a shortcut) on your desktop that was deleted, you should be able to find the folder in your Recycle Bin and select it and click on RESTORE and that should put it back where it was .
If it was a folder and deleted and the recycle bin was emptied, it is lost unless you pay someone HIGH dollar to retrieve data from your harddrive that was deleted.
Hope this fixes ya up , post again if you need further assistance.
Regards..
Apr 09, 2009 | HP Hewlett Packard Pavilion A6200N PC...
WIFI not working
This is a common problem on hp laptops in the 2000 and 6000 series. It is caused by a manufacturing defect on the mainboard. You may try and update your BIOS and see if it fixs it.. If it doesnt you will have to contact HP and they will give you a free repair if you still are under warranty (the warranty is 2 years here in Denmark)
BIOS update:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56284-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224052
PS: Please rate this solution
Mar 11, 2009 | HP Pavilion dv6000z Notebook
Wireless
I think your device has hardware switch to enable and disable wireless device. Please check the switch.
Dec 19, 2008 | Computers & Internet
I have a problem making a shortcut on my desktop for some of programs. They come up but when I click them, nothing happens.
How are you creating the shortcut? If you right click on your desktop and click on New -> Shortcut, then tell it where the actual program is located, it should work everytime. A simpler solution is to find the program in your start menu and simply right click and drag it onto the desktop then choose to create a shortcut here.
Dec 05, 2008 | Computers & Internet
The wireless keeps saying disabled.. it wont connect and it cant find the available networks.. there is no problem with the network cos it works fine on the ohter computers/laptops in the house and...
Hi sayeh,
I don't know if some of your IT friends had check the Wireless Zero COnfiguration,lets check it out.
start>run> type in services.msc
scroll down to Wireless Zero Configuration
check the status,
right click on it and click either start/restart
hope it helps
Jun 23, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
