Question about Samsung Digimax 240 Digital Camera
Battery power? I have had my camera for about a year and I haven't yet used it. Every time I turn it on it says low battery and shuts off. I change batteries, and now it doesnt turn on at all. Do I need a wall charger or something? Please help!! thank you
  • 1 more comment
  • Krystyn Mar 10, 2008
    the camera never really worked. it stayed on for about a minute when i first got it. Then, i'd put new batteries in and it'd do the same thing. Now it doesn't turn on at all. Do you think I should just purchase a new battery?
  • Krystyn Mar 11, 2008
    Can you send me a link that shows an example of what to get (Nimh batteries)? Im not a tech person whatsoever lol thanks for your time
  • Krystyn Mar 13, 2008
  • 149 Answers
Hi there, try to repalce a new battery, the battery needs to shack. it may be reparable but try a new one to test if it will work. ty
Posted on Mar 10, 2008
    President:
  • 1,944 Answers
Are you using the same type of batteries as the ones you used when the camera actually worked in the past?
My Powershot SX10 IS has worked perfectly for 2 years. Recently I needed to change batteries, and since I did, (4 AA batteries), no matter how many times I put in brand new batteries of all brands, I...
First off, make sure that you're using good quality batteries, and not generic alkaline. Rechargeable NiMH are best. Next possibility is that not all of the batteries are making contact in the case. Make sure that the terminals at the bottom of the battery case haven't been bent low. If any of the batteries sit lower in the case than the others, try bending its bottom terminal up just a little bit so that it sits a little higher in the case, possibly improving its contact.
Aug 29, 2011 | Canon PowerShot SX10 IS Digital Camera
When i turn on my camera with full recharge batteries, it shows low charge battery sign.my camera and batteries are one year old only.what to do?pls suggest.
Hi there if you use much this Camera last one year then its time to change the battery.If not then its a problem of your camera power transformer unit.
Dec 28, 2010 | Canon PowerShot SX120 IS Digital Camera
Camera shuts itself off
What is the age of the camera and how well used are the batteries? are you recording from battery or from power cable? The only things you can do are make sure the battery and power is good and make sure the recording media is good. With that in mind if the camera is older than 5 years, they have a battery inside the case that you cannot change. This battery keeps the date and time in memory and when it looses charge, the camera has to be sent in for repairs.
Dec 23, 2017 | Panasonic AG-DVC15 Mini DV Digital...
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
Camera shutting off indicating low battery
I had the same problem, apparently if you're using a external memory card that can cause this problem...
I didn't know that but I contacted Samsung and got mine repaired.
They put a note in saying the power board was faulty in the camera.
Much, much better now. I can take pictures like I used to be able to!
May 12, 2008 | Samsung Digimax A7 Digital Camera
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
Canon
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Dec 23, 2007 | Cameras
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Samsung Digimax 240 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
