Dvd/cd drive problems
Hi Keever,
I asked you about a dvd problem the other day. I am still trying to figure out how to take the top of the computer, managed to get the side panels off easily enough, but don't want to force anything.
Thanks for your help.
Maggie Wright
    Scholar:
  • 52 Answers
Sometimes the top has to slide either forward or backward BEFORE you pull up on it----------usually slides towards you if you are in front of the machine. Sometimes also you will see some plastic clips on each side that you have to pry outward very gently AT THE SAME TIME and then pull up on the top. Look at it very thouroughly from all angles and you will discover what has to be done. Sometimes there are a couple or more of screws that have to be unscrewed, but in most cases, it's just a plastic clip and/or the top slides before pulling up on it. Hope this helps. Keever
Posted on Mar 10, 2008
Have a Micro Innovations Model IC445C webcam that came with a CD, the CD doesn't do anything, now what
Hello Ruebesams, hi, here are the steps you need to do and check:
  1. Have your CD/DVD drive checked, try other CDs and see if it can read other CDs.
  2. Is your webcam CD a DVD? Placing a DVD on a CD drive will not do anything. you need a DVD drive to read DVD disk.
  3. Ask a friend if you can use his or her computer to copy the content of the CD or DVD to a flash drive, so that you can install the driver using a flash drive on your computer.
  4. If your driver disk still cannot be read by any other computer, I suggest you bring it back to your dealer and have it checked.
Aug 11, 2010 | Micro Innovations IC445C Webcam
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Dvd's & Cd's are not being read
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
May 16, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
DVD writer problem
Hi I am Vortash try uninstalling your cd from the device manager then re-booting and reload any software the installation wizard ask's for .. to uninstall the dvd from device manager ..click start ..,.Settings .... control panel...select Device manager ...click the + sign by the side of DVD /CD rom drives highlight your dvd and select actions next to file at the top of the window then uninstall re-boot your system and let windows do the rest hope this helps REgards Vortash
May 15, 2009 | HP Computers & Internet
Existing CD recorder drive now not working after installed DVD RW
You are to clean registry manually now. Nero still has leftovers in there.
Mar 26, 2017 | LG (GSA5163D) DVD±RW Dual Layer...
Hi....trying to install vista into my laptop "presario c700"
check the boot sequence of your computer it must be on first boot from cd/dvd, if it is ok then thre is some problem with the DVD disk or drive.
Nov 08, 2008 | Compaq Presario C700T Notebook
I think it is desktop DVD ROM. P3, P4, P5 are power connectors for HDD and DVD.
Upside down the DVDROM. you can see 4 screws there. remove the screws. Open the tray using a small hole in the front panel. You can easily remove the top panel now.
Jul 02, 2017 | Acer AL1716Bbd 17" LCD Monitor
My sister yanked the main plug loose from my computer the other day and it's been acting up ever since, but it never gave me a problem with playing my CD-ROM until a couple of hours ago. My computer froze,...
Take the Cd drive out and take off the top. Look inside for a tiny glass cover. Looks like a small light bulb. Clean the fine layer of dust off this glass and you just might be back in business. keever
Mar 06, 2008 | Computers & Internet
Take the drive out and carefully take off the top. The lase shines through a very small glass cover that looks like a small light bulb. Clean the very fine layer of dust off of this glass "eye" and this MIGHT fix your problem. I have seen this happen dozens, if not hundreds of times. Keever
Mar 06, 2008 | Acer AL1716Bbd 17" LCD Monitor
Sony DRU 700A, can't play/write DVD
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive Good luck!
Oct 28, 2006 | Sony Dual layer (DRU700A) DVD±RW Dual...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
