Question about Canon Cameras
'Stuck' pop-up flash unit.
I have a ca**n 400D digital SLR. The built in Pop-up flash unit ** longer pops-up when needed. I suspect a little orange juice has got into the gap between the pop-up unit and the camera body. I get an error message **. 05. Is there anything I can do at home before giving up and taking it to be repaired?
  • erin1031 Aug 01, 2008
    ERROR 05 HOW TO FIX IT AND MAKE WORK
Canon flash won't pop up
Flash will not pop up automatically if you're in manual mode. Try putting it in the green auto mode, then try again. Still not working? See if the little flash symbol button is on OFF. If so, put it to ON or auto. Should work.
Jul 08, 2014 | Canon EOS 40D Digital SLR Camera Digital...
Cannon error 05
Error 05 means that something mechanically prevents built in flash to pop up. Ensure that nothing is blocking flash. Switch in P mode and press flash button to pop it up. If it does not pop up - try _gently_ to help it to pop up. If you succed in popping up the flash - check it for any dirt with can prevent flash from popping up.
May 29, 2010 | Canon EOS 400D Digital Camera
Flash
mcomijohns. WHAT ARE YOU SUGGESTING!!!! Stop.
Lakshmy Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it pop up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.) PLease let u shave more information for a proper solution.
Sep 26, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Built in flash problem
most likely you have set the camera to the auto mode and you are shooting in a place with plenty of light.
your camera has a sensor which activates the flash when needed.
you can set the camera to the manual mode so that you can chose the flash to work even in the day.
Aug 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Cameras Logo
511 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
