Question about Dryers
Zanussi Tumble Dryer Model TC7103W ** Heat
Heater stopped working changed whole heater unit still ** good?
  • Anonymous Mar 18, 2014
    dryer works but the heater doesn't work
    Novelist:
    Champion:
  • 244 Answers
Have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
Posted on Mar 10, 2008
Tumble dryer does not produce hot air on hot mode, do I need a new heater element?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Zanussi Dryers
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Nov 23, 2008 | Zanussi TC7114W Electric Dryer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Zanussi tumble dryer model TC7103W ** heat, machine runns ok, changed compleate heater unit including thermostat.
it could be the timer what sometimes happens is a wire can burn out or have a break in it have had some dryers do this to me and have had to change part of the wiring to fix the customers dryer
Mar 10, 2008 | Dryers
ZANUSSI TC7103W
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
Bolts
Mar 28, 2007 | Zanussi TC7114W Electric Dryer
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Dryers Logo
294 people viewed this question
Top Dryers Experts
