Question about ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095)
My motherboard its always rebooting my computer so my monitor is off but my cpu is still open !
  • dakel Mar 11, 2008
    thank you very much for the good solution you gave! i really appreciate it!
    Problem Solver:
  • 17 Answers
Try remove and put again Memories, Video Card and Other PCI - Remove Ipod and others USB devices like a Printer, if all this not work, check the power supply.
gamba.support@hotmail.com (MSN) if you need more help.
Posted on Mar 10, 2008
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
Computer continiously ask for reboot
DFirst thing to do is to UNdo everything you have just done: Memory Upgrade and CPU Cooler. If normal operation returns, try the upgrades, one at a time, to narrow down the source of the problem. I suspect the memory, as a DIMM chip not correctly set up will cause this problem. Let me know what it does, please? jaye.ellen@gmail.com
Dec 12, 2009 | ASUS P4SP-MX Motherboard
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
Replaced motherboard and power supply. Monitor says No VGA Signal and No DVI Signal, then goes to sleep. Will not wake. Unable to load OS because I cannot view the monitor.
Power up your computer. As soon as you can open the DVD/CD drawer and put in your OS CD. shut down the computer then reboot. Let me know how you make out. Thanks Dana
Aug 21, 2009 | HP W2007 LCD Monitor
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
Computer restart
Restarts are often power related. Either your power supply is failing or underpowered, or the voltage regulation modules on the motherboard are failing. Look at all the capacitors (they look like little batteries) on the motherboard and look for brown/orange seepage, if you see some then you will need to replace your motherboard.
Next to test your power supply, unplugg as many devices as possible, remove add-in network and sound cards, unplugg unnecessary USB devices, and rerun your job. If it reboots still then there is a good chance that your power supply is the problem.
Of course, like most computer problems, it is important to rule out software as the culprit. Since corrupted drivers and program files can cause Windows to reboot the computer. The easiest way for you to test this is to re-install Windows. A fresh install of Windows that still reboots will point out a hardware problem.
Jun 20, 2008 | Intel D865GBF Motherboard
My computer computer shot down always in 15 mins.
Dear Dakel,
Please go to the control panel => power options => then monitor off (it will be 15 min. so select it never)
Your problem will be solved.
Cheerup and Be Happy Always
Mar 11, 2008 | ASUS K8V-MX Motherboard
ASUS M2N32-SLI Deluxe/Wireless Edition ATX Motherboard (1254095) Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
