Stand_by hi all, i am having a little problem with my aiwa tv. it,s on stand-by & i cant turn it on, i do not have the remote control for it only a universal one.yes you gessed it,i bought a second hand tv without the remote control.could you please help me find the code numbers for a universal one for all remote, thew model number of the tv is TV-SE141K
  • 1 more comment
  • spitch Jul 14, 2008
    I bought universal remote control (urc22b-8),now i lost the manual, how do i get the tv codes and types that it operates?
  • Lukito Ramadani Mar 04, 2009
    my tv same problem with rench007
  • Bruno Gamba
    Bruno Gamba May 11, 2010
    Do you need a IR codes, or your tv does not function? - MSN gamba.support@hotmail.com
    Genius:
  • 1,694 Answers
Www.remotecodelists.com hope that helps....................T.
Posted on Mar 10, 2008
What seems be the problem of my aiwa 14 inch tv, thus it has something to do with tv system ic?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
May 24, 2014 | Aiwa Televison & Video
My aiwa tv a 219 remote locked how to open it.
Aiwa television comes with the option of blocking certain channels from viewing, allowing you to control which channels people using the television can view. However, if you forget the code that you entered to block the channels, you might find yourself unable to watch those channels. Fortunately, there are a couple of buttons on the television and the remote that you can press to reset the PIN and customer ID numbers, which unblocks the channels.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Oct 30, 2012 | Aiwa Televison & Video
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
Jun 24, 2010 | Aiwa Televison & Video
Codes
Hi, Take a look at this link, I hope it helps you, if not let me know.
http://www.remotecodelist.com/remotes/
Regards - Anthony
Feb 08, 2010 | Emerson Televison & Video
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Rca remote is not workin on my aiwa tv
porfa necesito el codigo para un televisor aiwa me pueden ayudar xporfavor
May 06, 2009 | RCA RCU300WBL Remote Control
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Codes list required for Gemini G610S multi remote
Try 230, 231. 232, 233, 248 for the VCR.
Try 009, 011, 019, 024, 025, 027, 028, 051, 062, 068, 107, 115, 120, 131, 132, 139, 167, 169, 171 for TV.
Sorry - cannot help with DVD.
Len
Jun 06, 2008 | Gemini 1 Device Universal Television...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
