I was wiping the hard drive when the laptop just stopped working.
it will not cut on.
what do i do
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
install a software called CC cleaner it will wipe your disk and replenish like it anew one .
www.x64bitdownload.com here you can it or try simple google search.
