Question about Intel D845GVSR Motherboard
Problem with Sound on D845GVSR
I have a Intel 845GVSR mobo and 1gb ram. The problem is I cannot get the mic to work on the machine. The playback works fine but the mic does not.
I have formatted th HDD, installed the drivers, codes but nothing seems to work.
Appreciate a solution ASAP
  • 25 Answers
See the audio jumper of ur mother board
Posted on Mar 10, 2008
My mother board is intel 845gvsr,it not coming any display,before days it's working properly.but now it's not working,even bios settings also not showing.some times it's working but only 5 to 10 min only...
just a thought have you checked that its not shorting out on the case? when you installed the motherboard did you put in the spacers?
if you have then i would suspect the psu check that the fan it running when you switch it on
John
Feb 07, 2011 | Intel D845GVSR Motherboard
I have Intel Orginal 845GVSR motherboard with 2.4 ghz Processor and 256 ddr Ram. Can I increase my Ram to 1 gm with 400 fsb speed
Yes you can, the speed will be increased approximately more than 50%. There's also advantage if you can install two 512mb, which you'll see it as "dual channel", sometimes this is better as per the system configuration. Good luck. Thank you for using FixYa.
May 14, 2010 | Intel D845GVSR Motherboard
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Graphic driver
THE WINDOWS OS SEVEN SUPPORT WINDOWS XP DRIVERS SO DOWNLOAD graphic driver FROM FOLLOWING URL:
http://tinyurl.com/cfmn3g
& INSTALL
Apr 29, 2009 | Intel D845GVSR Motherboard
I have Intel 845GVSR Motherboard, 2.4GHz Processor, 1GB RAM
Yes it will. Just make sure to buy the proper hdd. If your board has SATA II connections then you would need a SATA II hdd. If it is just SATA then a SATA II drive would not work. Your other option would be an IDE hdd. If your system has a cable that looks like a big ribbon connected to your existing hdd then it's an ide drive. Hope this helps & please remember to rate my answer. Thanks.
Jan 27, 2009 | Intel D845GVSR Motherboard
Ram upgradetion
Yes U can use maximum 2GB RAM in ur motherboard...
Dec 03, 2008 | Intel D845GVSR Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Audio output problem in Desktop motherboard
if you use back panel sound
so need to jumper setting on mobo
jumper short 1-2 , 5-6 , 8-9
audio jumper is near by front side pci slot 1,2
Mar 01, 2008 | Intel D845GVSR Motherboard
Intel D845GVSR Motherboard Logo
152 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
