Washer won't agitate or spin
My washer fills properly, but won't agitate or spin. I tried to turn the agitator by hand, and it will only turn approx 1 inch either direction, like a locked steering wheel does. Water drains at right time, rinse cycle runs at right time, just no agitation or spin cycle. I purchased it in 1998, but it could have been 1997...it came new in a home that I purchased in 1998. Please describe the specifics of your problem below. We'll add your post as a comment to nitanita's Washer won't agitate or spin problem, and notify you when a new solution is offered. Simpson Esprit 650 - does all the normal fill, drain etc but most of the time will not agitate or spin. Clutch is okay and drum does move a fraction (as if clutch is coming in/out) and lid switch is fine. Sometimes it will go though after a little patience and a couple of cycles.
  • KatharineAus Jun 11, 2008
    hi my machine wont spin either i tried cleaning filters and playing around with fan belt but it still wont work i thought it could be a crink in the hse too but its not please help
2 Suggested Answers
SOURCE: Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Posted on Jan 14, 2010
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
what you need is a motor coupling. it connects to the motor and the other end of connects to the transmission. the part about 10.00 but i recomend having a professional install it because it can be tricky. i suggest you buy the part at a parts store or even online to get it even cheaper and then have someone install.
Jan 23, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
