Question about Whirlpool ED2FHSS Side by Side Refrigerator
Freezer working but fridge isn't! My freezer is running but my fridge is shutdown! Sorta like the fridge just giving power to the freezer and not to the fridge!
  • 1 more comment
  • vickers 1 Aug 17, 2008
    The same exact thing has happened to mine! Freezer working but fridge isn't! My freezer is running but my fridge is shutdown! Sorta like the fridge just giving power to the freezer and not to the fridge!
  • joshuamw Dec 20, 2008
    I have the same problem, except it is my freezer that is turning off and the refrigerator is working fine. The refrigerator is out in the garage and it is winter, so I'm wondering if the cold is affecting the freezer some way?
  • ThomasClan Mar 30, 2009
    I have a Whirlpool side by side with water and ice dispenser that I purchased new 5 years ago, and I have had the same problem. I am having it again now....the fridge won't cool, but the freezer is all frosted up. If you look in the fridge, at the very top back left hand corner, there is a little grate that flows from the freezer to the fridge. There should be a strong, steady feeling of cold air coming through that grate. If there is not, and there is ice building up on that grate, and there is a lot of frost building up in the freezer, then there is likely a problem with a little motor that is on the freezer side of the appliance. This little motor has something to do with the defrost cycle of the freezer. WHY this should have a detrimental effect on the fridge is beyond me, except for bad design planning. It runs around $170-200.00 to repair. This is the second repair of the same issue in 5 years for me, and I am not thrilled with this Whirlpool fridge, believe me.
    Novelist:
  • 131 Answers
You have a frost issue. You may need a defrost timer, defrost thermostat, or defrost heater.
Posted on Mar 10, 2008
Magic chef RB150R freezer won't cool, refrigerator sorta cools. Freezer fan runs all the time
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 13, 2018 | Magic Chef Refrigerators
Westinghouse wse7000sa freezer light exploded and now fridge isn't working
Please recheck that model number. It is coming up as a washer.
Dec 02, 2012 | Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
The freezer works fine; the refrigerator isn't cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2011 | Refrigerators
Our jenair is not cold. the freezer is working, but fridge isn't and the motor keeps running.what is wrong with it?
need model # to give best help // but look for ice in freezer area it may be blocking the air flow .. and will cause long run times .. . if ice is found in ( no frost frig ) then you have a defrost problem .. mm hope this helps .. mm feed back pls ..
Jul 10, 2011 | Jenn-Air Refrigerators
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
Whirlpool ED2FHSS Side by Side Refrigerator Logo
445 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
