Question about Gateway FPD2275W LCD Monitor
HARDWARE & SOFTWARE
TO WORK TWO PEOPLE ON SINGLE SYSTEM USING TWO MONITORS & KEYBOARD & MOUSE ON ONE CPU, WHICH HARDWARE IS USED TO SYSTEM.
    Sergeant:
    Champion:
  • 277 Answers
How to set up computer
Hi, If your Computer a Desktop or is it a Notebook. If it is a Desktop, Plug in the Wires/connectors of the Monitor to the Desktop in the video port. Further you also have to plug in the Keyboard & the Mouse cables to their respective ports. After completing this, turn on the system. Once the System is on, if it is a preloaded computer, then you have to do the necessary settings as per your requirements & can be able to start using it directly.  If your system is not preloaded, then you will have to install the Operating system and then you have to install the drivers for the monitor, Keyboard & Mouse. Then you can install the Office software  & Other softwares as per your requirement. But whether it is a preloaded system or not, do not forget to install the Anti Virus Software in your system.
Feb 06, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Connecting wireless mouse and keyboard to new system
Just plug in a keyboard/mouse while upgrading sound like the best bet
Dec 08, 2007 | Computers & Internet
Microsoft laser desktop 5000 vs Windows 7
The software might not be compatible. but for you to use the wireless keyboard and mouse you don't need a software just plug the wireless adapter and sync the keyboard and mouse . it will start working
Jan 17, 2010 | Microsoft Wireless Laser Desktop 6000...
Hi MY Dell OptiPlex GX620 have a hardware
try the bios settings is your monitor in a grafics card slot
also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Nov 24, 2009 | Dell OptiPlex GX620n PC Desktop
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
My CPU is starting but my monitor is not the light
First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
May 12, 2009 | Intel Asus P5GL-MX 800MHz FSB 915GL...
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    My monitor, mouse and keyboard don't work
    Try cleaning out the PC. Clean the CPU fan, remove all dust build up within the case. Canned air helps a lot. Blow out the power supply too. When you are able to power up the PC, do you see the case LED's light up / flashing?
    I'm keeping in mind that when you loose the video display you also loose the use of the PS2 keyboard & PS2 mouse. If the CPU is over heating the system will shut down the PC.
    If you're system is still under warranty, please call Fujitsu.
    http://www.fujitsu-siemens.com/home/products/personal_computers/scaleo_p.html
    You may need a new power supply, CPU or board. Sorry!
    Jun 13, 2008 | Computers & Internet
    Chnaging a pully on a car
    KVM - Means: (Keyboard, Video Mouse) switch is a hardware device that allows a single keyboard, video(monitor) and mouse to be used with a number of computers
    Sorry, this is wrong grouping to help with fixing a car. ;)
    Mar 28, 2008 | Computers & Internet
    Gateway FPD2275W LCD Monitor Logo
    43 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
